Code Help!
Old Mar 18, 2007 | 07:39 PM
KYcountry's Avatar
Question Code Help!
I did the code check on my truck(thread :2001 Cmmins diesel smoked to death!) The code I got was P1693. Can anyone tell me what this means?
Old Mar 18, 2007 | 07:41 PM
madhat's Avatar
Administrator/Jarhead
Check here...
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Nevermind, it's not there.
??? Make sure that's the right code...
Old Mar 18, 2007 | 07:44 PM
79warlock's Avatar
It means there is a DTC in your JTEC controller.
Old Mar 18, 2007 | 07:52 PM
phox_mulder's Avatar
It's the code letting you know there is a code.
We have 2 main computers, the ECM and the PCM, and often they aren't on speaking terms, so that code is present in one telling you the other computer has a code.
You'll need a code scanner to find it.
Find someone in you area with a Smarty, or take it to the Dealership.
phox
Old Mar 18, 2007 | 08:38 PM
madhat's Avatar
Can we add that to the FAQ section with the codes in it?
Old Mar 19, 2007 | 11:15 AM
DodgeChicInFL's Avatar
I have that code (P1693) coming up on mine too as well as P0122 ( I know is TPS) and P0720. I did a online search for the P1693 yesterady after I got that code come up on mine and found it said: Engine Control Module.
I am having problems w/ my Trans shifting. Don't want to till RPM's are at 3 and sometimes still don't so I wonder if any of my 3 codes is the issue to my problem.
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
