Check Engine Light on after I removed turbo silencer ring
Alright, Guys last night I unplugged what I think looked like a mass air flow sensor at the air box to remove the air intake line to the turbo. After I removed the silencer ring from the turbo and put the air intake line back on I forgot hook this sensor back up before I went down the road. Once I realized I didn't hook up the sensor because I noticed the check engine light was on I pulled over and hooked it back up. Now my check engine light won't go out. I disconnected both batteries trying to reset the computer and sure enough the check engine light is still on. How can I reset this with out going to the dealer or autozone.
Acutually it takes "three good trips." The definition of three good trips is ambiguous but it basically means allowing the engine to get up to temp 3 times.
I did the exact same thing that you did and my CEL went away fairly quickly.
VikingDiesel
154
Oct 13, 2017 10:28 AM
05-6X6
Feb 14, 2006 09:47 AM
Mark Hodowanec
Sep 13, 2005 06:56 PM
YFZ
Aug 11, 2005 07:25 PM
