Check Engine Light!
It's weird that it will charge full field for a while.
I'm taking the plunge and replacing the alt. I think I have tried everything else!
Thanks Dave.
Thanks Dave.
When you test the alt by disconnecting the field terms. do you just hook the wires directly to the alt where the field terms screwed into? What kind of voltage should i see? Guessing this also bypasses the voltage reg.
Alternator?
I was looking for a list of what the engine light codes mean and I came acroos this forum discussion. I am having the exact same problem with my truck at 216,000 miles. So did you replace the alternator? Did that fix the problem? Did the 1 2 4 1 5 5 go away after replacing the alternator?
Thanks,
Bryan
Thanks,
Bryan
Mine too.... I've had similar problems like this in the past (which I forgot to mention to you) and discovered it was just the ground wire coming off the negative battery cable had worked its way loose. Not this time though. Alternator was toast.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
