Check Engine Light!
Old Jun 6, 2005 | 09:55 PM
mhuppertz's Avatar
Check Engine Light!
The Check Engine Light came on today, and stayed on. The Water light has been on for a year. Everything else seems to be working (air, cruise, etc.) so I don't think it is the CPS. I have no idea why a diesel would have a check engine light anyway!
Any ideas????
Mark
Old Jun 7, 2005 | 12:25 AM
Hemi Cat's Avatar
If the light is red, you might want to check your oil. I'm not sure of the inputs that turn that light on, but you probably have a sensor wire that fell off or broke. You could also try plugging in a scan tool to read the code to identify the source. I think auto zone does it for free.
Old Jun 9, 2005 | 10:32 PM
mhuppertz's Avatar
Could my factory oil pressure gauge be lying to me? It seems to be working as normal. Oil level is fine. It comed on when I hit the highway going home.
Is there a scan tool that will work on a 1st gen?
Old Jun 10, 2005 | 04:31 PM
Yeah, any scan tool that will work on a '93 Dodge will work on your truck. Take it to an AutoZone, they'll read the codes for free.
Old Jun 10, 2005 | 04:38 PM
mhuppertz's Avatar
Dave,
Looking at your sig block again, where did you get the high flow banjo's?
Old Jun 10, 2005 | 10:36 PM
Geno's Garage. They sell them for 24 valve trucks, but they are the same size as ours.
http://198.104.149.53/CoastalData/sh...ID=593&CATID=1
Get one solid and one tapped. You can use the tapped one for fuel pressure or just put a pipe plug in it so you don't lose the bleed. I've got a 1.5" 15 psi glycerin filled gauge threaded into mine since I had it laying around. It bounces from 3 to 7 psi at hot idle, revved up it gives a steady 6 psi.
Old Jun 11, 2005 | 10:42 AM
mhuppertz's Avatar
Does the PCM retain data? If the light isn't on when I test it will I get any hisorical data?
Old Jun 11, 2005 | 11:55 AM
Some codes are retained through a certain number of key cycles, others are wiped out when you shut off the truck.
Old Jun 15, 2005 | 10:15 AM
mhuppertz's Avatar
My computer is throwing a code 24, which is TPS voltage high or low. That's wierd because I have a standard that does not have a tps (that I know of).
Is my PCM getting Alzheimers?
Old Jun 15, 2005 | 07:32 PM
That is wierd. No factory cruise?
Old Jun 15, 2005 | 07:35 PM
mhuppertz's Avatar
It does have factory cruise, but it doesn't have the typical TPS that the automatic has. If there is a TPS, I don't see it......
Old Jun 15, 2005 | 07:42 PM
No, I was just trying to find a difference between my PCM and yours. Mine hasn't set code 24. I don't understand why yours would start throwing a code for a sensor it shouldn't even be looking for. Is that the only code?
Old Jun 15, 2005 | 07:45 PM
mhuppertz's Avatar
The exact code is:
1 2 4 1 5 5
The PCM may have been marginally damaged when the serpentine took out the crank trigger.
Old Jun 19, 2005 | 12:43 AM
mhuppertz's Avatar
More on the mystery. I notices the voltage needle riding low when the "check engine" light is on. Also, the cruise control is very weak when the light is on, and lets go frequently. Interestingly, the air stays on, so it's probably not the crank position sensor.
I'm thinking low voltage to the PCM, but I can't figure out why. Id doesn't happen all the time, or it would run the battery down.
I'm at a loss.
Oh, and there seems to be more interference in the radio than before, and it increases with engine speed. I think someone stole my Cummins and stuck in a pinging gasser!
Old Jun 19, 2005 | 06:21 AM
My FSM says the TPS code shouldn't show up on a manual trans truck. Maybe you should take it to AutoZone and let them scan it and see what comes up. Very wierd.
