Broken Timing Pin
Old Jul 8, 2006 | 01:55 PM
Txwelder's Avatar
Broken Timing Pin
Ok Im adjusting the valves and used the pin at TDC for #1. Get through the first half of the job and go to pull the timing pin back out because it says "Engine Damage Will Occur" if I try to turn the crank with the pin engaged. Well the pin wont move, so I start prying on it. You guessed it, the outer half of the pin broke off. Now what? Can I just rotate the engine and break the rest of the pin off and go about the job? What will happen if the pin is sheared by the gear? I just dont want to break my truck for little piece of plastic. Thanks.
Kevin
Old Jul 8, 2006 | 03:07 PM
alaskanassassin's Avatar
Look up a post I did a couple of months ago about my broken timing pin. I got the steel locking ring out with a hooking type screwdriver. It came with my pick set from snap-on. I got it in fairly easy with a deep socket that is the same diameter as the pin. Best of luck. Doug
Old Jul 12, 2006 | 11:51 AM
Txwelder's Avatar
Did some reading on this site and another well known Dodge diesel site, decided to just break it off. The remainder of the pin did not fall out so I have no oil leak and if I ever have to pull the pump I will buy another pin. As for now it is fine.
Dusty Ratcliff
May 1, 2016 12:00 PM
mechmagcn
Oct 12, 2011 10:29 AM
Dr. Evil
Oct 2, 2008 01:17 PM
royta
Oct 23, 2007 07:04 PM
snackdaddy
May 31, 2005 06:58 PM
