broken timing pin - how big of a deal?
Old Oct 23, 2007 | 12:50 PM
royta's Avatar
Other than not being able to find TDC without lowering the 1st Intake & Exhaust valves to the piston, how big of a deal is it if the timing pin breaks off? I believe it is made of plastic. Could it damage the engine if the tip comes out of the hole in the cam gear? If it does fall out, it would either get chewed up by the gears and/or fall into the oil pan. It would then get picked up in the oil filter without any chances of it plugging up a oil hole, correct?
Old Oct 23, 2007 | 03:31 PM
bob4x4's Avatar
No worries,it is plastic.I have been lucky maybe but have had a few brought to me over the years and been able to remove the broken piece using a sharp pick.
Bob
Old Oct 23, 2007 | 07:04 PM
infidel's Avatar
You can still find TDC with the timing pin located on the side of the pump if the plastic pin on back breaks.
I find it easier to use anyway.
Dusty Ratcliff
May 1, 2016 12:00 PM
Totallyrad
Jul 31, 2014 04:34 PM
Dr. Evil
Oct 2, 2008 01:17 PM
Txwelder
Jul 12, 2006 11:51 AM
snackdaddy
May 31, 2005 06:58 PM
