Brake Problems
Old Feb 26, 2009 | 11:43 AM
mmcmahon's Avatar
Brake Problems
I have a '99 2500 2wd with a cummings just stock. I have replaced my rear drums becuase of the same issue. The rear brakes are working alot harder than the front. I've worked on alot of vehicles and did bleed and adjust a bunch!! It must be the master cylinder or?? I would appreciate any help or ideas. Thanks
Old Feb 26, 2009 | 11:47 AM
nkennedy's Avatar
Could be master cylinder. Could be proportioning valve. Could be hoses on front.
Old Mar 1, 2009 | 11:15 AM
mmcmahon's Avatar
I just didn't want to start guessing and spend more money than I have to.
Old Mar 1, 2009 | 11:23 AM
I believe that truck has a height sensing proportioning valve. Take a look at to see if the linkage has broken or come out of adjustment and the valve is pushed up like you have a heavy load in the bed.
Old Mar 2, 2009 | 10:20 AM
mmcmahon's Avatar
I do not see anything like that. There are 2 diferent valve bodies. One looks like just a splitter and the other maybe an ABS valve body as it has a small box by it?
Old Mar 2, 2009 | 01:32 PM
benroberts3605's Avatar
i had this same issue on a dakota and the fluid got contaminated and the hoses swelled on it. they worked fine for the first few pumps then were vary tight after that till it sat.
Old Mar 2, 2009 | 06:05 PM
mmcmahon's Avatar
Mine are just tight all the time. Very touchy usually at low stop speed.
dieselluvr
Dec 29, 2013 11:02 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
jahluvdiesel
Dec 26, 2002 01:15 AM
