Block Heaters
Old Jan 28, 2003 | 06:34 PM
Junk Yard Dog's Avatar
Block Heaters
Anyone have a rough idea as to what range in watts a typical block heater uses? Have 4 trucks being plugged in and need to know how big the circuit should be. Any &quot;rough&quot; ideas would be appreciated.<br>Thanx, Rick
Old Jan 28, 2003 | 06:39 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Block Heaters
CattleHauler (Ricki) just replaced his, it was a 750W-120V.
Old Jan 31, 2003 | 11:41 AM
Superduty12v's Avatar
Muted User
Re:Block Heaters
How hot you think the block heater keeps at?
Old Jan 31, 2003 | 04:25 PM
converteddzlr's Avatar
Re:Block Heaters
Keeps the hood of the truck snow free during a light snowfall. And the truck thinks that it's actually warm when it starts up
Old Jan 31, 2003 | 07:12 PM
Muted User
Re:Block Heaters
I used my block heater when the temps got down to 7 degrees a couple of weeks ago.. didn't seem to do a whole lot for warm up. I'm pretty sure it was working because something was drawing enough current to make the plug spark when I unplugged it.
Old Jan 31, 2003 | 07:53 PM
figure_9_pro's Avatar
Re:Block Heaters
If you are going to use 4 heaters at the same time that will use about 12.5 amps @120 volts so a 15 or 20 amp circuit will do the trick
Old Feb 1, 2003 | 12:30 PM
Re:Block Heaters
Thanx for the reply's, we just went ahead and ran dual 20 amp lines just to be on the safe side.
Old Feb 1, 2003 | 03:41 PM
Commatoze's Avatar
Re:Block Heaters
[quote author=figure_9_pro link=board=13;threadid=10206;start=0#99059 date=1044064393]
[/quote]
I'm not sure what you based your figures on, fig. The heater consumes around 750 watt (pure resistive load) so that's around 6 amps and some change. So you're looking at about 25 amp total for the 4 vehicles. JYD, I think you made the right move with the 2 20 amp circuits.
Old Feb 1, 2003 | 03:54 PM
Re:Block Heaters
Commatoze, I actually came up with 6.5 amps per heater so it holds out on paper. Thanx again for all input
Old Feb 1, 2003 | 04:29 PM
Re:Block Heaters
OK OK so when I add it with a calculator instead of my head I come up with 25 amps.......I hate when that happens [undecided]
Old Feb 1, 2003 | 04:43 PM
Shovelhead's Avatar
Re:Block Heaters
[quote author=figure_9_pro link=board=13;threadid=10206;start=0#99332 date=1044138592]<br>OK OK so when I add it with a calculator instead of my head I come up with 25 amps.......I hate when that happens [undecided]<br>[/quote]<br><br>I can't count to 20 without taking my shoes off. <br><br>Like Jethro Clampett I studies Gozintas.
fireout2002
16
Feb 10, 2004 08:53 PM
PapaPerk
15
Dec 4, 2003 08:04 PM
XTOAK
Oct 27, 2003 10:16 AM
Commatoze
Feb 14, 2003 08:48 PM
powerstroke
Jan 6, 2003 11:31 PM
