Bearings in oil
Old Sep 29, 2007 | 10:21 AM
Redliner's Avatar
Bearings in oil
HELP My friend is changing oil in his 91 12 valve and took the drain plug out which is magnitized and there is 2 ball bearings on it!!! Where could these have came from?????
Old Sep 29, 2007 | 12:40 PM
Busboy's Avatar
It's not the 2 you found it's where are the rest of them? Does it have a turbo on it? If so that would be my first thought.
Old Sep 29, 2007 | 03:10 PM
They came from the vacuum pump.
Is the truck new to him?
Old Sep 30, 2007 | 12:03 PM
Redliner's Avatar
turbo spins fine and no excessive play. has had the truck for about a year now. whats up with the vaccum pump?????
Old Sep 30, 2007 | 04:52 PM
There are ball bearings in the vacuum pump (drives the power steering pump). Sounds like it's coming apart or one failed before your friend got the truck. Does the vacuum pump look newer than the rest of the engine?
Old Oct 1, 2007 | 12:41 PM
Redliner's Avatar
cant really tell, maybe. any way to tell if it is coming apart????
Old Oct 1, 2007 | 03:50 PM
Not without taking it off. You don't want it to seize up and get completely trashed when right now all you need is a bearing.
Old Oct 1, 2007 | 09:08 PM
duner's Avatar
how do the bearings from the vacuum pump get into the crankcase?
Old Oct 2, 2007 | 04:47 PM
There's a caged bearing right at the front of the pump on the old non-intercooled pumps. If that bearing fails, the ***** will drop right into the timing case and roll down the oil drain right into the pan. Relatively harmless as long as you catch the vacuum pump before the case gets all tore up from the parts thrashing around with no support.
Mutt68
Sep 25, 2012 12:51 PM
jschintgen
Oct 6, 2010 01:08 PM
Stamey
May 21, 2010 07:19 AM
Mabiad
Mar 17, 2009 01:30 PM
Need95-00CTD
Oct 15, 2008 05:09 PM
