Stored truck; prime turbo bearings with oil?
Old Mar 17, 2009 | 12:27 PM
Mabiad's Avatar
I've had my truck stored for six months. A gear head tells me I should prime the turbo bearings before I start the truck. I say "are you kidding?". I am thinking there must be residual oil on the bearings...enough to satisfy them until the unit gets full oil supply a few seconds later. I wonder if the turbo is even hardly moving before the oil gets to the bearings...?
Anyone know for sure if I should go through the exercise of priming the bearings?
Old Mar 17, 2009 | 01:22 PM
CTDSled's Avatar
I'm watching this too. Mine is stored and will be for six months..............
Old Mar 17, 2009 | 01:25 PM
haloman's Avatar
what is the ambient temp? If it is chilly I would plug it in for about 8hrs and let it get warmed up that way. Then start it and let idle for a bit. You should be fine.
Old Mar 17, 2009 | 01:30 PM
purduepurdy's Avatar
I would think that it would be like any engine stored for some time. No oil anywhere. Wonder if you could crank it over to get the oil pump pumping w/o injecting. I'm no mechanic though.
Be sure to use some Stabil and change the oil when you get back. Thinking moisture might be able to build up in the crankcase from heating/cooling??? Like I said not a mechanic.
00Dog
Apr 7, 2015 01:11 PM
Mutt68
Sep 25, 2012 12:51 PM
ccoop769
Oct 27, 2007 02:18 PM
Dale_K
Oct 22, 2007 07:46 PM
Eskimo
Jul 14, 2004 11:49 PM
