Battery selection. Which size?
Old Dec 6, 2002 | 07:01 PM
James Andres's Avatar
99 with the original mopars. With this colder weather I have noticed additional cranking and the voltage drops to the lower edge of the white range. It stays here for a couple minutes depending on how quick I get going. Prior winters it was never like this. Truck has been inside and plugged in. So I'm thinking time to replace these batteries before it gets really cold and I am left out in it. NAPA tells me their book recommends 700CCA batteries for my truck. Originals say 750 right on the tops. Would I regret going to a lower battery? ???
Old Dec 6, 2002 | 08:43 PM
dodgeram's Avatar
Re:Battery selection. Which size?
I got a couple 795 CCA batteries from walmart.........<br><br>they claimed they don't have any applications to fit my truck, but they were sitting right there on the shelf <br><br>
Old Dec 6, 2002 | 08:58 PM
DarrellB's Avatar
Go with as big as will fit in the battery trays. I was able to fit a couple of 880's under the hood in the trays but they just bearly fit. I would go any smaller than a 750, it takes 50 amps just to run the grid heaters, and that's a lot of juice when it's cold outside.<br><br>If moeny is no object go with a set of optima red tops, about $100 apeace. :'(<br><br>DB
Old Dec 6, 2002 | 09:19 PM
Redleg's Avatar
Autozone has a 900 for about $75 with a pretty good warranty
Old Dec 7, 2002 | 06:56 AM
richard's Avatar
I use batteries from a local store, I think they are made by exide but as far as size, they are a group 24F cca 1000
Old Dec 7, 2002 | 07:16 AM
Wow thanks for the quick replies. I'll tell my NAPA man I'll need to get my batteries elsewhere. Thanks!.
Old Dec 7, 2002 | 07:24 AM
pappyman's Avatar
I have used Interstate Batterys for years they cover a large range of useage and have some of the highest CCA of any of them and the warranty is great
Old Dec 7, 2002 | 09:04 AM
Smokee's Avatar
I second Pappyman on the Interstates.<br>george
Old Dec 13, 2002 | 03:01 AM
Dieseldude4x4's Avatar
Replaced mine several months ago with two NAPA Legends. 875 CCA if I remember right and about $78 a piece.<br>The right one always goes bad first then drags the left one down. My son is still using the left battery in his truck. <br>I had two 1225's in my 95 truck.
Old Dec 13, 2002 | 11:46 AM
bulthisl's Avatar
Yup 2-1000's on mine<br>They do nicely. ;D<br><br> : Eddie : 8)
Old Dec 15, 2002 | 05:07 AM
dalton4's Avatar
Replaced mine with two 1000 amp batteries from costco.
Old Mar 11, 2003 | 09:37 AM
casey's Avatar
get an iterstate rated #1 any of these bozo's that tell you to get one from NAPA,Cosco,or any other exide product don't know jack if you dont believe me go to consumer report. any battery made by johnson control is top notch . Interstate,DieHard you won't go wrong
Old Mar 11, 2003 | 10:26 AM
Lil Dog's Avatar
You have to be carefull with the large CCA small frame batteries. In those batteries they have all the plates really close together to make the 1000 CCA. But after a while in the cummins fired rams, the plate start to come loose and may touch inside the battery and cause the battery to loose its amps available.<br><br>IN our old first gens, we only got 1 1150 CCA battery to do the job, and its a big one. I have 2 in my rig that are too big to fit in the new battery trays, but its nice to have 2300 CCA on a cold morning.. I buy from Freightliner, I think they are Interstate.<br><br>J-eh
Old Mar 11, 2003 | 11:02 AM
BIG&BAD's Avatar
same here as dalton4
rabuntjer
Aug 24, 2012 05:36 PM
06SLTcs
Oct 28, 2011 09:43 AM
GK170
Mar 19, 2010 06:47 PM
Mexstan
13
Sep 22, 2003 12:15 PM
tippers
19
Jul 23, 2003 04:19 PM
