Trans. Fluid
Old Mar 9, 2003 | 08:28 PM
SolidJunkMM's Avatar
Trans. Fluid
I had a tranny line separate on me today while I was on the interstate. It came apart at the joint between the rubber and steel line at the tranny cooler. I was able to get it back together with a hose clamp, and a buddy brought me some fluid. My question is when I changed the fluid a couple months ago I used Valvoline PLus 3 fluid. All he was able to find was Dexron III/Mercon. Will running this type of fluid damage my trans? Should I drain it out and go back to the Plus 3? Help!!!<br><br>TIA<br><br>Joe
Old Mar 9, 2003 | 09:08 PM
dingo's Avatar
Re:Trans. Fluid
I have the same question. Deeler changer filter and fluid with atf 3 , also ? how many quarts for 99 auto 4x4??<br><br> dingo
Old Mar 10, 2003 | 02:27 AM
LHartman's Avatar
Re:Trans. Fluid
I wrote a major oil company about this. This company didn't make an ATF type 3 and I was using their Dex/Merc III. They advised that you can use Dexron/Mercon to top off a Chrysler transmission but if you refill with it, you will often have hard shifts and general driveability complaints.
Old Mar 10, 2003 | 06:05 AM
pappyman's Avatar
Re:Trans. Fluid
You could have problems with the Dexron III/Mercon...Dodge spend alot of time and money to develop ATF+3 for use with these trannys....I would advise to drain and refill with ATF+3 and maybe change the cooler lines to the 2001 style that get rid of the quick disconnect fittings
http://www.dodgeram.org/tech/transmi..._couplings.htm
My cooler line also released going down the highway and I lost all my fluid...it cost me a rebuilt tranny and I updated my tranny cooler lines this time....good luck
Old Mar 10, 2003 | 06:53 AM
Holsteinman's Avatar
Re:Trans. Fluid
Trans with a lock up torque converter need to use ATF plus. On the older ones with out lock up you can use dextron.<br><br>Paul
Old Mar 10, 2003 | 07:56 AM
Bearfoot2's Avatar
Re:Trans. Fluid
[quote author=dingo link=board=13;threadid=12026;start=0#113777 date=1047265717]
dingo
[/quote]
ATF +3 ONLY (stock tranny) Total oil capacity with a stock tranny is 17 qts. (includes TC) For tranny oil change 4 qts. (Do not flush system !!)
Trannys other than stock check with builder or installer.
Stan
Old Mar 10, 2003 | 09:52 AM
TPilaske's Avatar
Re:Trans. Fluid
Should'nt it be the Chrysler ATF+4? ???
Old Mar 10, 2003 | 10:02 AM
pappyman's Avatar
Re:Trans. Fluid
Chrysler four-speed automatics only use ATF+3 (ATF+4 for 2000 and up vehicles) ;D<br>
Old Mar 10, 2003 | 10:05 AM
TPilaske's Avatar
Re:Trans. Fluid
[quote author=pappyman link=board=13;threadid=12026;start=0#113932 date=1047312124]<br>Chrysler four-speed automatics only use ATF+3 (ATF+4 for 2000 and up vehicles) ;D<br><br>[/quote]<br><br>ahhhhh.... ;D
Old Mar 10, 2003 | 10:17 AM
Bearfoot2's Avatar
Re:Trans. Fluid
JPilaske, I don't know about the ATF +4. In my owners manual for a '98 24v (says the same for the '99) pg. 206 Selection Of Lubricant<br> Chrysler Automatic Transmission Fluid identified as ATF+3 or ATF+3 Type 7176 should be used to assure optimum transmission performance.<br><br>
CAUTION
<br><br>USING TRANSMISSION FLUIDS OTHER THAN ATF+3 MAY CAUSE DETERIORATION IN SHIFT QUALITY AND/OR TORQUE CONVERTER CLUTCH SHUDDER<br><br>Stan
Old Mar 10, 2003 | 10:18 AM
Bearfoot2's Avatar
Re:Trans. Fluid
Oooopppps - I see that Pappyman got there while I was playing with the keyboard. :
Old Mar 10, 2003 | 10:42 AM
Dodgezilla's Avatar
Re:Trans. Fluid
ATF+4 is Chryslers Synthetic version of the ATF+3. I was gonna buy some but it's $10.00 per quart!! I think the 02s &amp; 03s come with the +4 but on all older models they always recommended ATF+3 only. I think there is a TSB on this if you go to your lookup and type ATF+4. Also, Chrysler is the only place to buy ATF+4!! :-X
Old Mar 10, 2003 | 10:50 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Trans. Fluid
There is another option for ATF+4 fluid:
Amsoil ATF
Old Mar 10, 2003 | 12:54 PM
TPilaske's Avatar
Re:Trans. Fluid
I am going to try the Amsoil this spring... ;D<br><br><br>Chrysler ATF+4 was $22/gallon last time I purchased it...
Old Mar 10, 2003 | 03:28 PM
Dodgezilla's Avatar
Re:Trans. Fluid
What's the price on that Amsoil ATF???
