Bands???
Old Aug 20, 2004 | 11:53 AM
DODGE4X4's Avatar
Question Bands???
My tranny is holding 1st to long and if I get on it hard it feels like it is slipping. Could this just be the bands? I have never touched them before and the truck has 102890k on it.
Old Aug 20, 2004 | 02:08 PM
MARKY MARK's Avatar
Mine does the same thing. I'm afraid to take it to the dealer though. I've just been living with it. Mine's a '99 with 75,000 miles.
Mark
Old Aug 20, 2004 | 03:19 PM
Smokee's Avatar
I think it is a throttle position problem.
Old Aug 20, 2004 | 05:20 PM
DODGE4X4's Avatar
Ok I just drove home and 1st gear is hanging up. If feels like if it were a standard tranny and you are holding the clutch to long. All the other gears are good and it isn't doing it every time but more than not. I called the dealer to see what he thought and said maybe the bands or some kind of a pressure switch?? I need my truck on Sunday to haul a load of cattle so I'm in a major bind here.
Old Aug 21, 2004 | 02:40 PM
thumper 549's Avatar
Not the bands....t.p.s. or a blown clutch "o" ring, if it cant sustain preasure it will hang in the last gear.....adj. the bands will never cure anything except shift timing a little.....they get way too much attn.,,they are nohing more then a brake band that stops a drum ( sungear) from turning
t.m.o.
Old Aug 21, 2004 | 10:30 PM
DODGE4X4's Avatar
How do I go about fixing a T.P.S problem
Old Aug 21, 2004 | 10:47 PM
DODGE4X4's Avatar
I reset my APPS a week ago and it took care of all the erratic shifting that I was having. APPS = TPS correct?
Old Aug 22, 2004 | 01:06 PM
DODGE4X4's Avatar
Well I adjusted the front band and it took care of the problem 100%. But now I have another problem above the cross-member that hold the tranny up is a sensor going into the tranny. Problem is that I some how ripped the wires out of the sensor and need a new plug for it The truck is running perfect with this senor like this but surely it is there for a reason.
onehitwonder53
Apr 11, 2015 07:09 PM
Valv
Apr 12, 2005 10:19 AM
03racecarhauler
14
Feb 22, 2004 11:05 PM
DODGE4X4
Oct 27, 2003 05:49 AM
MYTRNx3
Sep 12, 2003 11:58 AM
