adjusting bands
Old Feb 10, 2004 | 11:10 AM
03racecarhauler's Avatar
adjusting bands
I did a seach, and didnt find anything, can anyone tell me how to adjust bands, or is it somthing the dealer should do for me. I pull a 9000lb 22ft race trailer most of the time and I feel the tranny is starting to slip.
Old Feb 10, 2004 | 02:50 PM
SBishop's Avatar
Do you have 47RE or 48RE tranny?
Old Feb 10, 2004 | 06:26 PM
dodgedude361's Avatar
welcom to the site, fill out yer sig so ppl can help you
Old Feb 19, 2004 | 01:07 AM
sorry about the wait, i havnt bieng interested in my truck or modding it until this darned website....
now its all over, i was planning on the reliable stock truck and never doing anything exept for the maintenance.
I finally called the dealer and found out that i have the 48re, so i suppose that is good news.
so the question is is it easy to do or should i get the dealer to do it?.
Old Feb 19, 2004 | 06:32 PM
y-knot's Avatar
I think it is easy, and feel that most people who are not turned off by getting dirt under their nail would be able to do it also. You would need to look-up the torque specs for the two bands, (Mine is 72 in/lbs), and what the back-off is. Then it's just a matter of drooping the pan, tightening the band bolt to there required torque, and backing them off the right amount (usually around 2 1/2 turns). That is really all there is, put the pan on and top off with fluids. I think the adjustment is good, but I would bet the slip you notice is your Torque Converter. Good luck.
Old Feb 19, 2004 | 08:39 PM
CAKUZ's Avatar
ADJUST BANDS
Originally posted by 03racecarhauler
so the question is is it easy to do or should i get the dealer to do it?. [/B]
The bands are not difficult to adjust. You need to buy a new filter and pan gasket plus about 4 qts. of fluid will drain when you remove the pan. You will need an accurate Inch pound torque wrench, some Torx sockets and other metric sockets
The Front (kickdown) band adj. screw is on the L.H. side of the trans. just above the manual & throttle levers. To adjust loosen the locknut, turn screw a couple turns to make sure threads are clean and that screw turns freely. Tighten to 72 "#. , Back screw off exactly 1- 3/4 turns. Hold screw in this position and tighten locknut.
The messy part is next. Remove oil pan so you can get to the adj. screw for the Rear (Low/Reverse) band. Loosen locknut and torque screw to 72"#. Back off 3 turns and tighten locknut. Bands are now adjusted to DC specs. Most Chrysler transmissions are all torqued to 72"# but the 'back off' is different on some others. I checked my 2003 Ram factory Service Manual to make sure I have the correct specs for the 48re.
I would always replace the filter when I removed the pan. Just remove the screws (2 -3) and pull filter off. Replace and tighten screws to 35"#. DO NOT over tighten as you could warp aluminum valve body. Torque on pan bolts is 125"#..
Add the specified ATF+4 (synthetic) fluid. Do not overfill.
Hope this helps you decide if you want to do it yourself. Let us know.
Old Feb 20, 2004 | 06:10 AM
Fummins's Avatar
Talk about your good instructions..
Old Feb 20, 2004 | 06:29 AM
Smokee's Avatar
Well, easy or not, I would take it to the dealer if it is under warranty. You should not have to be adjusting the bands yet, IMHO.
Old Feb 20, 2004 | 01:15 PM
wow those are some sweet instructions, i'll probably tackle it myself. i have 26,500 miles on my truck and i am always pulling my trailer. the dealer will tell me whats going on with the tranny today, its in getting a new cooler because of the Recall. so i'll probably do it my self unless you think i should let them do it because i do have the "slipping".
thanks.
Old Feb 20, 2004 | 01:58 PM
SBishop's Avatar
If you are having a problem with the tranny "slipping", I would let the dealer take a look at it. This way, the problem is on record and covered under the 36/36,000 warranty.
Old Feb 20, 2004 | 02:31 PM
CAKUZ's Avatar
Re: adjusting bands
. [/B]
If the trans. is slipping ,adjusting the bands may not correct it as the clutch plates are most likely worn too. The lining is rather thin and it does not take a lot to do them in. Slipping is not good. I would adjust the bands B-4 I took it tothe dealer because the service manual says to adjust bands, replace filter and fluid at 15,000 and 60,00 miles. They could say if the trans. was not serviced at 15 K miles they may give you a hastle abuot warranty as some look fof anything to 'Void' it.
If there has been problems with the cooler, - could have something to do with slipping. Heat is an automatic trans. worst ememy, and towing is hard on an automatic as it produces more heat. It's the very reason I got the 6 spd. manual.
Let me know if I can help in any way.
Kuz Email - CAKUZ1@peoplepc.com
Old Feb 20, 2004 | 03:02 PM
SBishop's Avatar
On a 2003, the transmission bands are scheduled for adjustment every 30,000 miles with a filter and fluid change. It is still under warranty conditions.
Old Feb 20, 2004 | 05:52 PM
CAKUZ's Avatar
You are correct, the maintenance schedule for service of the 48re trans. is every 30K miles, Not 15K as I said earlier today. I was running late for a dentist appointmend and in a hurry. Must have had a brain f**t. Since this is part of regular maintenance I do not think it is covered under warranty, no more than an oil change, air filter or tire rotation, etc would be covered.
Since the trans. is Not due for service and it is slipping, I think I would not touch it and strongly insist on a total rebuild or replacement. I started rebuilding and troubleshooting automatic transmissions in 1958 and know that once a trans. starts slipping it will not hold up very long. They may adjust and service it and it may be OK for a while but I would not trust it far from home. Be my luck it would last until 36,001 miles on it.
At the very least I would get it in writting from the dealer that it was slipping so when it goes out there would be proof of defects before warranty ran out.
Kuz
Old Feb 21, 2004 | 01:18 PM
I spent the bucks on a 5 year 100,000 mile dodge warranty so im good for a while, the truck is going into the dealer, I had it in for the recalls and they replaced the cooler. the tranny tech looked at my fluid and said it was "mighty dark" and he wouldnt be surprised if sonthing wasnt normal, they are going to do the service on the tranny ( so he can see what kind of junk is in there) but at least i have the 100,000 miles for it to implode .
Old Feb 22, 2004 | 11:05 PM
Sasquatch's Avatar
tranny is covered by 7 year 70,000 mile powertrain warranty
onehitwonder53
Apr 11, 2015 07:09 PM
Ridiculous
Jan 25, 2006 08:13 PM
EClancy
Aug 13, 2005 11:18 AM
CSAGrey1
Aug 4, 2005 02:52 PM
Valv
Apr 12, 2005 10:19 AM
