Axle seal passenger Side Dana 60
Old Apr 7, 2005 | 06:54 AM
Truckman's Avatar
Question Axle seal passenger Side Dana 60
A question for all you Dana Guru's out there,
Is it possible to put the passenger side axle seal in, Just by removing the axle and the 4X4 actuator fork? Or do you have to pull the carrier out? I just did The Ball joint from HEL* Job ,And ended up having to do the passenger side twice because of a defective ball joint that would NOT take grease.,, Now I think My axle seal is starting to seep,,, It my just be some fluid coming out from removing the axle (wishful thinking). Any help would be great.
Thanks in advance.
Bob
Old Apr 7, 2005 | 07:41 AM
BIGBADBOB's Avatar
I would wait a few days to see if it just the fluid in the tube. I had my axle out to do a U joint and it left me thinking the seal let go. It dried up in a week and never came back. Fluid level stayed good.
Bob
Old Apr 7, 2005 | 09:11 AM
infidel's Avatar
Bob is right I've seen some take over 500 miles for the fluid that got past the seal into the tube to finally drain out. The seal can also deform if the axle is allowed to hang in a position other than normal but will return to it's original shape after a while.
Also make sure your fluid is only filled to Dana's recommended level, 3/4" below the fill hole. To fill it to the bottom of the hole is a recipe for a leak and will also cause the differential to run hotter.
Old Apr 7, 2005 | 09:31 AM
berner's Avatar
Re: Axle seal passenger Side Dana 60
Thanks in advance.
Bob
To answer your question, yes it is possible. You have to rig up a puller of sorts with some allthread and appropiate plates and pull the seal into place from the outside of the diff. There's another recent thread that mentions a website called Quad4x4. There's a picture of a puller setup there. It's tricky getting the seal started straight and you have to work on the thin side of the seal (ie. backwards from a regular seal installation). It very easy to bend the seal. I had to do mine twice.
As Bill and Bob said though, wait a while. It may stop leaking on it's own. You could also take the CAD housing off and check to see if the spring on the seal popped off. Good luck. They're a PITA to change.
Old Apr 7, 2005 | 03:17 PM
RCW's Avatar
RCW
Should you have to change the seal, the puller and driver kit and new seals, along with a video instruction tape is available from these guys: http://www.quad4x4.com/Dodge%20Frt%2...Axle_Seal_Kits
Having the proper puller and installer will save you a ton of frustration.
Old Apr 7, 2005 | 06:24 PM
infidel's Avatar
Here's instructions also
http://dieselpowerman.tripod.com/Fro...xle%20Tech.htm
Old Apr 8, 2005 | 06:22 PM
Truckman's Avatar
Thanks for all your replies, I just got back from Vermont Skiing for a couple of days. I checked the level in Vermont and it seemed OK,, So I am going to wait a little while and see if the seeping stops. But if I have to replace it I will do it thought the 4 wheel drive actuator access. I just replaced all the Ball joints and it is so nice not hearing all that Clunking up front.
Thanks for all your help.
CJK96
Mar 23, 2012 04:49 PM
Bob_24VCTD
Jul 26, 2008 12:27 AM
Flashman
Jun 9, 2008 07:00 PM
dieselrob
Mar 1, 2006 07:33 AM
SSV1761982
Jun 24, 2004 11:15 AM
