Dana 70 axle seal?
Old Feb 28, 2006 | 01:22 PM
dieselrob's Avatar
Dana 70 axle seal?
Ok i got a leaky axle seal on my d 70. Any body ever replace one or the bearing? If so you know about the lock nut in the hub. My ? is does it take a special socket to fit in there or will a standard impact work? I was lookin threw the haynes manual and their pics show what looks to be a special or homemade socket. Would like to know befor im in there and have no tool available and the truck is sitting apart for days.
Old Feb 28, 2006 | 02:53 PM
JKM's Avatar
JKM
You need an axle nut socket , NAPA sells them AFAIK. It is a very easy job.
Old Feb 28, 2006 | 03:15 PM
CTD NUT's Avatar
What JKM said.....NAPA sells some reasonably priced spindle nut sockets and you don't even need an impact gun - a 1/2" ratchet will work fine.....also, your full floating D70 does not have any axle seals...it only has inner wheel bearing hub seals.
Old Feb 28, 2006 | 04:26 PM
dieselrob's Avatar
Is there a certain size to this socket or is this the only one out there?
Old Mar 1, 2006 | 07:33 AM
G1625S's Avatar
it's 2&9/16'', but the socket itself has very thin walls to fit inside the hub. A standard socket will not fit in there.
jigdog
Dec 26, 2014 12:53 PM
flynhigh205
Mar 26, 2012 05:20 PM
Flashman
Jun 9, 2008 07:00 PM
Truckman
Apr 8, 2005 06:22 PM
SSV1761982
Jun 24, 2004 11:15 AM
