Axle nut
Old Sep 22, 2004 | 09:05 AM
scottsjeeprolet's Avatar
Question Axle nut
I need to change my front rotors 99 3500 4X4 Cummins and need to know what size socket i need for the large castle nut that attaches to the front axle. anybody know?
thanks
scotte
Old Sep 22, 2004 | 09:15 AM
Mcmopar's Avatar
I believe mine was 1 11/16
Old Sep 22, 2004 | 01:13 PM
Junk Yard Dog's Avatar
1 11/16 is correct
Rick
Old Sep 22, 2004 | 04:01 PM
Sidewinder's Avatar
Yes 1-11/16" but when I had to do mine i couldn't find one anywhere so I used a 1-3/4". Wouldn't recommend it but it does work if you get stuck
Old Sep 24, 2004 | 12:14 PM
Thanks
Thanks for the input. I had to borrow the 3/4" rachet set from work.
It took me 3.5 hours to get the brakes done on one side of the truck. I would really like to meet the engineer who designed the brakes and kick him in the A$$.
I am going to do the other side tonight.
thanks again
scotte
Old Sep 24, 2004 | 12:26 PM
nitrousn's Avatar
wry are you removing the axle nut to do a brake job. i can do it in an hours time.
Old Sep 24, 2004 | 02:09 PM
infidel's Avatar
He probably wanted to turn or replace the rotors. When just replacing pads it takes me longer to retorque the wheel lug nuts than to do the whole rest of the job.
Old Sep 26, 2004 | 09:50 AM
Details
Yes i was replacing the pads and rotors. wait till you have to change the rotors and you will know what i am talkin about.
Wheel bearings, can you buy just the bearings and seals for the front Dana 60 or do you have to buy the whole unit assembled. i priced the unit at Autozone and it was $371, ouch.
anyone know?
thanks
scotte
Old Sep 26, 2004 | 12:22 PM
infidel's Avatar
You have to buy the entire unit bearing.
Last time I bought one from Napa they were $241/ea
Old Sep 26, 2004 | 04:32 PM
F. Flack's Avatar
The 99 requires a different hub assembly than the 95. NAPA sold me the wrong hub last year -- it wore out in less than 12 months. Fortunately they gave me a full credit for the wrong hub since it was their mistake (normally $399.39). The one for the 99 is Left/Right specific, and comes with the ABS sensor/wire (and is rated for more weight). I cut the wire off since it was not needed for my truck.
The (Dana 60) hub assembly is a sealed unit, and cannot be serviced/repacked. Only choice is to replace the whole unit.
Franklin
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
Bradtothebone
Dec 24, 2003 12:07 PM
kd460
14
Jun 9, 2003 07:47 PM
TexRam
17
Apr 14, 2003 07:14 PM
