Rear axle nut torque/lock tabs
Old Dec 22, 2003 | 03:07 PM
Bradtothebone's Avatar
I was in the process of changing my rear axles seals, and in the book it says to torque the nut to 120-140 ft-pds... Now which is it? Cause I was always taught to tighten it so there is so slop/no preload either?!! So to me 20 spread seems rather high.... Also can you believe the price of them little nut locks? Over 10 bucks CDN. each..... For the 2 seals, 2axle flange gaskets and 2 of the locks it was 140 bucks CDN...
Old Dec 23, 2003 | 07:36 PM
P Kennedy's Avatar
Re:Rear axle nut torque/lock tabs
Take a big wrench tighten until tight and then back off approx. 1/8 turn or hub turns freely without hub/bearing play. Bet you enjoying buying all your parts at Dodge didn't you, bearings and seals available at bearing supply houses, Permatex automotive silicone black/grey/blue/red etc.= gasket maker works on the drive axles just fine. Lock nuts are now available at NAPA along with locking ****- you save 40-50% OK. Drive for 15 minutes at highway speed and check hubs for heat- warm is OK, can't hold hand on too tight. Make sure hub is prelubed after cleaning check diff level after couple of runs. PK
Old Dec 23, 2003 | 09:10 PM
Hey thanks.... I got it all going...I torqued it to 120 and it spun good by hand....But I will do the highway drive and check it again as I read this post after I did it ..
Next time I will go to a bearing supply house....
Old Dec 24, 2003 | 12:07 PM
thumper 549's Avatar
they are talking pre tighten then back off do this a few times with the wheel rotating then just snug (if it has a outer lock nut on top of it that can be snorked dwn. pretty good.)
If you leave your preload at 120 lbs. thats going to be to tight!
Clane
Jun 2, 2012 03:31 PM
bkoz
Feb 22, 2008 09:21 AM
Oilguy
Jan 22, 2007 07:37 AM
jdeereboy
Jun 24, 2005 04:39 PM
David Gardner
May 13, 2003 03:54 PM
