should the fan be running when the engine is cold?
Re:should the fan be running when the engine is cold?
That's normal. The fan never stops spinning unless the engine is shut down. Mine roars until third gear and then releases on cold mornings. As long as it releases and quietens down after you start going up through the gears, it is normal.
Now I thought the fan would mysteriously come on when needed according to temperature, by use of a clutch. I know when it's hot out and I'm pulling a load the fan will come on with authority, run for a while until the temp decreases, shut off, come back on etc. It will cycle on and off or if it's hot enough it will stay on.
BTW Marine....our trucks could be twins....see sig below.
Yours looks alot PRETTIER than mine does!
The fan is on all the time, but the fan clutch determines how fast it will spin according to the temp.
Mike
Mike
[quote author=jigdog link=board=4;threadid=23746;start=0#msg226542 date=1071874048]
marine whats a horton ? electric?
[/quote]
It's electromagnetic. http://www.hortoninc.com/products/products.asp
It is on my wish list.
Mike
[/quote]
Mike
[quote author=jigdog link=board=4;threadid=23746;start=0#msg226758 date=1071902861]
mike i think its on my wish list now too ;D
[/quote]
;D
Mike
[/quote]
;DMike
92smokin blacky
Oct 7, 2011 03:08 PM
wood_n_soldier
Dec 16, 2003 07:07 AM
