asap! my water fuel serpater drain wont close
Old Jan 6, 2006 | 06:11 PM
IntakeRacing's Avatar
i have to go to work in like 50 mins and i just did an oil change... drain the water fuel serperator and now the **** thing won't close where that lil lever is for draining.
normally i just push it towards the engine and down and she closes... now it wont' close at all.
please and thank you.
Old Jan 6, 2006 | 07:57 PM
RCW's Avatar
RCW
You can fold the drain hose and double wire it in a very tight pinch to get you by until you can pull the drain valve and get whatever is stuck in the thing out.
Old Jan 6, 2006 | 08:26 PM
phox_mulder's Avatar
Might be some little piece of something lodged in there,
excercising the valve usually frees it up so it can close.
phox
Old Jan 6, 2006 | 09:16 PM
TORQUE's Avatar
You'll need to remove the 4 screws holding drain valve onto canister, and replace all 4 o-rings. 2 in drain valve inside the round tube, and 2 on mouting flange to canister. A generic o-ring kit with different size o-rings will fix it up, lube em with fuel.
Old Jan 24, 2006 | 12:25 PM
yup and thank you for the help although i just saw this now and i fixed the truck that night. i pulled her into the shop.. took it off and it was all frozen inside the drain.. and when i tryed to "exercise" the lever i broke it so i just popped in a new one. problem solved. and one of the o-rings were shot too.
Thanks for the help though guys.
Sean
ZPOD
18
Sep 23, 2010 10:37 AM
19mike92
Apr 9, 2010 10:08 PM
Bad Ramer Jamer
Dec 26, 2007 09:42 PM
CTDinMT
May 19, 2004 09:19 AM
wooff
May 1, 2003 11:22 AM
