Keep a close eye on your Drain plug!
Old May 18, 2004 | 08:18 PM
CTDinMT's Avatar
Man, I crawled under the truck yesterday to take some exaust measurements, and lo and behold, I see a little oil about to drip off the oil pan drain plug. Hadn't touched it since my last oil change 3k ago. Sure enough, it was finger loose. So I cranked it back down nice and snug, but man, I bout had a heart attack when I got to thinking if I hadn't looked under there, I woulda lost the plug and all my pressure by now. And the scary thing is I know I torqued the plug down good when I put it in. Are the vibes enough on a CTD that this is something I should keep an eye on in the future? Shouldn't matter, but the plug is Geno's magnetic tip plug w/ the fiber washer that came w/ it. -Steve
Old May 18, 2004 | 08:44 PM
TurboTed's Avatar
That's kinda weird alright. When I did my first change at about 4000mi. mine was only finger tight also! (My brother's was tough to take off on the first change.)
Old May 19, 2004 | 04:20 AM
Dodgezilla's Avatar
Don't torque it down too tight or it will crack and you will leak even more oil...
Old May 19, 2004 | 06:49 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Could it be the aftermarket plug you're using? I've never had a problem with my plug loosening and I change my oil every 7500 miles.
Old May 19, 2004 | 08:05 AM
Commatoze's Avatar
I'm pretty sure Geno's had a problem with one of their plugs some time ago with backing out. I believe it was the magnetic variety, Superplug or something like that.
Old May 19, 2004 | 08:41 AM
rangerst's Avatar
I swear mine tighten up between changes.
Oh! that was the old motor! Better check this one out! Thanks....sty
Old May 19, 2004 | 09:19 AM
propinc's Avatar
I have heard that if you over tighten the plug which is easy to do from what I understand it will leak from then on ... this fella suggested using a torque wrench to tighten the plug? I think I would look into the problem before something goes a stray like the oil pan ...... this note now was hear say from another Cummins owner maybe someone can confirm what I heard
wytesyko
Oct 22, 2011 06:52 PM
tritont
23
Sep 3, 2008 01:46 PM
highrpms
25
Jul 15, 2008 03:57 PM
