keep an eye on your fuel lines......
Old Aug 30, 2008 | 09:34 AM
tritont's Avatar
I was examining my engine yesterday, just making sure things were copacetic and notice fuel around the rail. Under closer inspection, I found that all the high pressure ( solid lines ) were somewhat loose. All of them !
I went through tightening and found that most if not all needed a good 1/4 to 1/2 turn on them.
Like with the rail to injector lines, there's no torque specs for these lines but, they're like AN fittings to where as long as they're snug they won't leak.
As a preventative measure, it's a good idea for everyone to check these lines every once in a while. If left loose too long, they can crack, the head on them can become deformed and not seal right and/or, you could end up with running issues because of air being drawn in.
Old Aug 30, 2008 | 09:38 AM
wap's Avatar
wap
Thanks for the heads up
Old Aug 30, 2008 | 10:49 AM
chrleb1's Avatar
Well if you would put some muscle into it, it probably wouldn't be a problem....
Old Aug 30, 2008 | 11:15 AM
tritont's Avatar
That has nothing to do with it. They were on tight. Obviously they can come loose over time. Tighten them too much and they're guaranteed to leak as you will deform the ends just like the connector tubes
btw... you're welcome for getting some info that might prevent you from having some grief.
Old Aug 30, 2008 | 11:21 AM
rmalone's Avatar
He's just hasseling you, take it easy airdale. And your right overtightening those suckers is a great way to buy new ones.
Old Aug 30, 2008 | 12:41 PM
matego's Avatar
madhat's monkey boy...
Thanks for the heads-up. I am going to check them when I run the valves again this weekend.
Some guys here dont run their engines long enough to develop a leak. Trailer queens
J/K
Old Aug 30, 2008 | 05:26 PM
chrleb1's Avatar
Geez!!!! What size of the bed did you get kicked out of this morning?!
I was just playing around.
Old Aug 30, 2008 | 05:27 PM
chrleb1's Avatar
J/K
If I'd get mine running this could be the case.
Old Aug 30, 2008 | 08:23 PM
lmills's Avatar
Actually, there is a spec. They get tightened to 22 ft lbs or 30 Nm as per the FSM
Old Aug 30, 2008 | 08:29 PM
GOT BOOST?'s Avatar
My torque wrench read exactly "Gist tight enuff" and then a little. Jay
Old Aug 30, 2008 | 08:32 PM
lmills's Avatar
I usually go by the 1/4 turn before it breaks rule. LOL
Old Aug 30, 2008 | 08:33 PM
tritont's Avatar
Ford service manual... dude, you're on the wrong page ! LOL
I never saw that in the service manual. I'm talking about the hard high psi lines. There's specs for everything else but, not for these lines that I've found.
Old Aug 30, 2008 | 08:45 PM
tritont's Avatar
Ok, I found it and you're right. It's only showing the lines to the tubes though but does say in writing... " all HP lines"
I'm like you though.... tighten to just before it breaks.
Old Aug 30, 2008 | 08:49 PM
lmills's Avatar
your absolutely right. It is hidden in a different section towards the beginning of the section for the 5.9s. I have no idea why they would not include it in the section where they show the installation of the injectors and the plumbing. All the other tq specs are in the installation instructions, but those.
Old Aug 30, 2008 | 11:08 PM
ataboy9026's Avatar
How exactly do you get a torque wrench onto a nut with a fuel line anyway? Use the "just tight enough method". I did have a line come loose at injector #6 at the head and lost about 30 gallons of fuel in a matter of 50 miles. Was spraying onto and being absorbed by the firewall insulation and then dripping onto ground. But I checked the others and found a few more that took a little turn to get them snug. And it took 90k miles to come loose as I had never touched them before. Everything was still stock. There is also a line that connects straight into the back of the head that is a real treat to try and get to, if you need a good laugh at yourself get a wrench on there and snug it up! My girlfriend thought I was trying to have sex with my truck with the grunting and my position.
