air in fuel
Old May 1, 2008 | 06:58 PM
benroberts3605's Avatar
air in fuel
I had a guy stop in my shop and said he changed his fuel filter and got air in the lines and now it wont run, ive changed mine a half dozen times and never had this problem. Any ideas on what i should tell the guy to do. By the way it was on a 98/99 24 valve
Old May 1, 2008 | 08:41 PM
BigIron70's Avatar
Cummins Guru
Fuel Pump Test
Print this bulletin and give it to him.
Old May 1, 2008 | 11:42 PM
PChouinard's Avatar
Bleed the air out of the lines. Loosen the injectors and see if ya have fuel there. Is the check valve on the return side of the vp good?
He isn't the only one to swallow a gulp of air after a filer change...
Old May 1, 2008 | 11:48 PM
PChouinard's Avatar
BTW, good post about the SB. This should be done before defaulting to the in-tank pump setup for 98/99's.
herb
Jul 18, 2008 08:25 AM
Tree DR
Mar 10, 2008 12:04 AM
Sixpack73
Aug 21, 2007 10:51 AM
BIGHEAD
Jul 24, 2006 07:49 PM
