Rich fuel mix or air fuel ratio = hot exhaust?
Old Mar 9, 2008 | 11:44 AM
Tree DR's Avatar
If the air fuel ratio is running rich does that make the exaust hotter?
What is the exaust temp on most truck at 65 with no or little wind. Of course 2wd, 4wd and numerous other factors. What I hope to find out is if my truck is hotter than most at 65 then maybe that explains something about mpg.
What sensors would make the ecm think it was to cool and needed to add fuel to keep the temp right? Maybe a IAT sensor?
Old Mar 9, 2008 | 12:06 PM
Raspy's Avatar
If you are talking about a diesel there is no real rich and lean. It's always rich at the actual point of ignition, at the injector tip, and too lean to burn out away from that point, near the cylinder wall. In other words there is always an excess of air in the chamber unless the engine is at full power and smoking black. The fuel is not pre-mixed with air to a ratio.
More power and later timing make the exhaust hotter, especially at lower RPM.
I don't remember for sure but I think mine runs at about 600* (pre turbo) on the road at about 65.
John
Old Mar 9, 2008 | 01:39 PM
carl48's Avatar
if you are trying to get better fuel milage, the lower you can get egt's at crusing speed the higher the mpg's, this held true for 14 mechanical changes and even worked on program c
Old Mar 9, 2008 | 05:27 PM
Tree DR's Avatar
So if my egts are around 700 then what can be done to change it?
Old Mar 10, 2008 | 12:04 AM
Dieselnick's Avatar
700 doesn't sound out of line. Where is your EGT probe mounted? The closer it is to the head, the hotter your readings.
Nick
Asher
Nov 7, 2007 03:06 PM
MmmDieselFumes
Oct 28, 2007 11:39 PM
chrisgreenup
15
Dec 20, 2005 09:53 AM
duallydave
Aug 7, 2005 09:38 PM
