Air Comp.
Old Aug 10, 2008 | 02:37 PM
valk's Avatar
Air Comp.
Air comp. seizedup,so I ordered a new one. Old one was already off, so putting the new one on easy,but how do I pull a vaccum? I have the equipment, but don't know how to use it. Help
Old Aug 10, 2008 | 04:45 PM
johnh's Avatar
i don't know about any body else but i don't know what you're talking about..... are you refering to the vacuum pump??
Old Aug 10, 2008 | 05:42 PM
duner's Avatar
A/C compressor?
Old Aug 10, 2008 | 06:28 PM
elucho02's Avatar
NEED HELP!!!!! Transmission temp. light comin on in dash! after about 10-12 miles. tow/haul light auto maticly engages.Ive changed filter-blew out cooler lines-cleanedout thermostat in air cooler!!! Any advise would be greatly appreiciated
Old Aug 10, 2008 | 06:31 PM
duner's Avatar
you should start a new thread for answers to this question.
Old Aug 10, 2008 | 06:38 PM
elucho02's Avatar
computer illiterate
Sorry Didnt realize I could
Old Aug 10, 2008 | 06:58 PM
BIGROD's Avatar
Make sure you change yhe dryer and the filter. After everything is changed hook up your gages to the lines and the center hose to the vacuum pump. Turn the pump on open both valves on the gages let it run for 30 to 45 mins. turn valves off first then pump. Make sure you add on the low side only.
Just remember that if you do not know what you are doing it would be worth paying someone who does. Blowing the seals out of a new compressor would cost you a new compressor.
Hope this helps
Old Aug 14, 2008 | 07:37 PM
dozer12216's Avatar
Yes, for your own safety, get someone qualified to complete repairs. I will not attempt to advise over internet how to complete.
herb
Jul 18, 2008 08:25 AM
James Lucas
14
Aug 29, 2003 11:24 AM
hellotbone
Jul 12, 2003 12:58 AM
hellotbone
18
May 16, 2003 04:40 PM
danlit
Feb 13, 2003 10:53 AM
