ABS light and brake light on !!
This is my first posting hope i'm in the right place. I have a 99 2500 4x4 diesel. I'm having trouble with my ABS and brake light staying on. I've tried to reset my comp. but they still keep coming back when I get to about 40-50 mph. Also my cruise control is not working which started when the lights showed up. Just for info. I changed my speed sensor but it didn't help. Can anyone help me?
It sounds like you changed out the right sensor, make sure you connected the harness securely. I suppose you could have gotten a bad sensor from the dealer...
i had the same thing happen, after i changed my front ball joints. i replaced my front abs sensors. and i lost one one of the line clamps, the sensor line wore through on my rim. i replaced it and tied the new one back. its fine now. just a thought.
The stoplight switch resides on the brake pedal arm, up toward the pivot point, facing the firewall. It will have a connector that has 6 wires going to it and is adjustable for each application. FYI their are 3 circuits in the switch. One for the ABS, another for the cruise control cut off and the third of course for the stoplights. Ask for a stoplight switch for your application, they come with installation instructions. The tip off for you problem was the lights coming on after a speed of 20 MPH, without 4 wheel ABS. Hope this helps.
BTW, if you still have the old speed sensor, you might want to keep it, it's probably still good.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
mr T
Feb 24, 2007 06:42 AM
