Clutch problems??
Old Apr 5, 2007 | 06:00 PM
Matt Lambrech's Avatar
Clutch problems??
Hi, stopped for a six pack on the way home from work and the truck would not go in to gear wen I left to go home. Turned off the motor and started in gear to get home. Grinds going in to gear and when in gear I hit the clutch it slippes some but still wants to go. Is it the clutch or the slave? There was no signs of any trouble before. 2001 6 spd
Old Apr 5, 2007 | 06:29 PM
masterphreak's Avatar
Sounds like a bad master or slave. Look and see if you can see any fluid puddles in your driveway. Sometimes they fail inside but don't show any signs of leaking. I'm sure more will chime in on your problem.
Old Apr 5, 2007 | 06:35 PM
Thanks, Dry like a cummins should be no puddles. Thinkin it might be the clutch disk or through out berring
Old Apr 5, 2007 | 07:51 PM
03qclb5spd's Avatar
I would think if it was the throwout bearing that it would be making a lot of noise, squeaking-type sound.
Old Apr 5, 2007 | 08:20 PM
vzdude's Avatar
DTR's 'Go to Guy'
Saw one rip the center splines out of the disc once! Acted just like you are describing. Clutch stuck fine ( no slipping), but a bear to shift! But I would have to think easier. Slave cyl or master cyl probably. Throw out brgs. are usually pretty annoyingly loud, and should still release the clutch. You need to try and watch a few things while a buddy is pushing pedal. Get a feel for what is going on.
Old Apr 5, 2007 | 08:28 PM
no noises at all just feels as though the clutch isn't down enough. I never had a slave partially work. I even tried pumping thinking it lost bleed
Old Apr 6, 2007 | 12:25 AM
03qclb5spd's Avatar
Yep, mine started making a horrific grinding/squeaking noise that went on forever. It still worked, but it got to the point where all the bearings came out and shifting became very difficult, as well as pushing the pedal in....shifting into gear with the truck stopped and running was not possible.
Old Apr 6, 2007 | 02:32 AM
pdieselpu's Avatar
Master or slave to look at first. May have to disconnect and hook up a gage first to tell.
Old Apr 6, 2007 | 06:29 AM
mj007's Avatar
Don't know if this is your problem but I had one of the clutch disc torsion springs break on my old Chebby and it would not release and then would, then wouldn't, etc. ..... very intermittent. When I got it apart I discovered that the broken spring was catching the crankshaft flywheel bolts on occasion and giving me 'direct drive' This was a deal where one minute it was fine and the next minute it was as I described.
Old Apr 6, 2007 | 06:43 PM
Pulled the tranny and found the pilot shaft bearring was gone. Needles were in the clutch rattling around. Not bad for 265K miles on origional clutch.
Old Apr 7, 2007 | 04:10 AM
Road Traveler's Avatar
Hey thats not bad at all!!
DJ Turbo.
Oct 13, 2011 09:11 PM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
