98 24V Auto Trans Slipping
Old Jun 30, 2004 | 09:28 PM
ellmannbru's Avatar
I have a 98 24V with Automatic Trans. 67,000 Miles on vehicle. Transmission slips at 45-50 MPH 1600 RPM Jumps to about 2000. Does this both in and out of Overdive. Never plowed, no heavy towing at all. Is this a matter of band adjustment?
Side note: If left parked for 3-4 days takes 30 seconds(or less) for trans to engage, assume this is leak down or sign of larger problem.
Also can't figure out exactly what the warranty term was for the 98's. Any help greatly appreciated.
Note: Had a flat tire PRIOR to slippage. Put spare on(others were worn) and just replaced all 4 today. Could computer have sensed a difference?
Old Jun 30, 2004 | 11:15 PM
dodgediesel4x4's Avatar
Not to question your mechanical intelligence, but have you checked the level of your tranny fluid? When was the last time you changed it or had the system flushed? Not trying to put you down, but thinking of the simplist things 1st, then we can take it from there.
Old Jul 1, 2004 | 01:32 AM
BigBlue's Avatar
The time to engage is no big deal. All that happened is the fluid drained from your torque converter. It's perfectly normal. I'd change the fluid and see if that helps. If that doesn't, then definately a band adjustment.
Old Jul 1, 2004 | 07:03 AM
j-fox's Avatar
If it is going in and out of lock-up, then it usually is an issue with electrical noise. It needs a filter. Call DTT , they have them.
As far as the slow starts, it is correct that the converter drains back after a long sit. Ussually over night. Start the truck and put it in neutral for 30 seconds.
Sometimes fresh fluid slows the drain back problem.
It is caused by several issues, one which is common is the converter bushing to snout clearance is a little high. Don't worry about it.
Old Jul 5, 2004 | 04:40 PM
ellmannbru's Avatar
Thanks for all the input. Going to dealer tomorrow, any "scams" they may try to pull?
And can anyone post a link to DTT??
Thanks Much.
Old Jul 5, 2004 | 05:25 PM
Wolfeman's Avatar
DTT 1 866 504 4002
PS I suggest you talk to DTT BEFORE making any commitment to the dealer. It could save you a lot of money - I know.
Old Jul 5, 2004 | 07:02 PM
j-fox's Avatar
Here is the link DTT .
Old Jul 6, 2004 | 08:50 PM
ellmannbru's Avatar
Reprogrammed computer and all is good! Thanks!
Old Jul 6, 2004 | 11:51 PM
Cumminsdude's Avatar
Just curious, did they reprogram the comp because the TC was locking and unlocking and how much did they charge you? Thanks
Old Jul 7, 2004 | 05:37 PM
ellmannbru's Avatar
Was slipping out of Lock up. Charged the shop minimum, $72.00
Clayton AMerman Dodge in Peapack NJ (They've been there for like 100 years).
Old Jul 8, 2004 | 05:36 PM
thumper 549's Avatar
a band adj will not fix it!!!!!!!!!!!!!!!!!!!!!!!!
dtc503
Dec 21, 2007 01:03 PM
raybob_99
Jan 27, 2007 03:34 PM
91.5CTDBanks
Dec 15, 2006 02:08 AM
bglz42
Mar 18, 2006 12:24 AM
wrk24wheel
Jul 14, 2004 04:46 PM
