Auto Trans Slipping?
Old Jul 13, 2004 | 06:56 PM
wrk24wheel's Avatar
I changed the fluid and filter and added a new mag-hytec pan to my 99' CTD about two weeks ago. The other day when I first took off from a cold start, engine and tranny were cold from sitting all night, the transmission acted as if I was in neutral. It reved then when I let off and gave it a little more gas it engaged. The tranny ran fine right after that. It has not done this again since then and I am wondering if this is something to worry about.
Old Jul 13, 2004 | 07:00 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Check your fluid level in Neutural to be sure it hasn't 'burped' an air pocket causing a low fluid condition.
Ed
Old Jul 14, 2004 | 04:46 PM
dcwm's Avatar
This seems to be common to the 99 Dodges here at work. It doesn't happen all the time just once in a while, you will jump in after setting all night , put in gear and.......nothin.....after about 3-5 seconds it will take hold and never have another problem.
Nearly 70000 miles later still going strong (just not out of the hole )
These are 1500's but still Dodge.
dtc503
Dec 21, 2007 01:03 PM
raybob_99
Jan 27, 2007 03:34 PM
91.5CTDBanks
Dec 15, 2006 02:08 AM
bglz42
Mar 18, 2006 12:24 AM
ellmannbru
Jul 8, 2004 05:36 PM
