'96 dodge cummins having charging problems help!
Old Aug 4, 2009 | 12:56 PM
lowefarms07's Avatar
I've got a 1996 dodge cummins automatic tranny, the alternator is rebuilded and it still won't charge. What can i do to fix this problem? Please help
Old Aug 4, 2009 | 02:16 PM
John Faughn's Avatar
These truck [ most all chry. products ] are a hair ball , when it comes to charging systems , because the regulator is in the ECM = computer .
They almost never go bad , but many give up and replace the ECM & or put in an external regulator .
The thing to do is good diagnostics 1st , fix only what is wrong , many times its just a connection fuse problem , fusible links at drivers side battery & grounds .
Are your battery terminals showing signs of corrosion ?
Old Aug 4, 2009 | 04:15 PM
Dr. Evil's Avatar
What kind of voltage are you seeing at your battery terminals with the truck running?
I believe there are some old threads here where people have wired in an external voltage regulator.
Old Aug 4, 2009 | 04:33 PM
Does your trans still shift into OD?
Old Aug 4, 2009 | 06:40 PM
infidel's Avatar
Read this https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Aug 5, 2009 | 08:29 AM
clops79's Avatar
check crank sender, had same prob on a 93 also any other gauges goofy
Old Aug 5, 2009 | 09:18 AM
Mcmopar's Avatar
BINGO!!!
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
khunter_2007
Feb 17, 2009 09:14 PM
boiler-rat
Nov 23, 2004 10:52 PM
