Out of town and charging system is.........not charging
Old Dec 8, 2010 | 08:23 PM
GLHS's Avatar
How many miles is the stock alternator good for?
I now have 205k on the stocker and the guage is showing about 11-12 volts with slow flashers and dim lights.
It then jumped up to around 13-14 for a while then, fell back.
Napa says they have a new one-no core, in stock for $175.
What else could be causing low voltage?
Old Dec 8, 2010 | 08:26 PM
chaikwa's Avatar
Mine was a broken wire behind the windshield washer bottle along the inner fender well that lead to the ECM. This was after I bought a new alternator and ECM.
Old Dec 8, 2010 | 08:34 PM
dkimmel's Avatar
Any respective parts store will test the alt for you.
Old Feb 24, 2011 | 06:56 PM
GLHS's Avatar
Been a few weeks.
Put some faith in Napa and they are as bad as Autozone, Checker, Western Auto, etc.
"Tested" the alternator and "Yep it's bad".
Bought and installed new one with same result.
I look at the sticky and find the ASD relay is a possibility; swapped with the a/c relay and no problems since.
So stock alternater was still good at 210,000 miles but brushes are almost to the limit. Might put it back on to see how long it will go.
Old Feb 25, 2011 | 07:00 AM
KD93's Avatar
Might as well, and return the NAPA one to them for a full refund.
Old Feb 25, 2011 | 07:23 AM
Trebor's Avatar
I thought there was a no return policy in effect at NAPA on all electrical items.
Old Feb 25, 2011 | 11:11 AM
KD93's Avatar
Beats me, I never shop there.
Old Feb 25, 2011 | 11:27 AM
ofcmarc's Avatar
Mine died around 220k.
The brushes were gone and the slip rings they were on were as well.
FWIW, it still tested good on the bench at 2 different parts stores. But put it onthe truck and it wouldn't charge.
Old Feb 25, 2011 | 11:47 AM
Richie O's Avatar
366 Spring Chicken
The only time they do a return is if its deffective. They have a no return policy because people would just throw parts at a problem and if it did not fix it they would return it. If some other part was defective in the same system it could cause the part they repaced to burn out or damage it. I worked the counter in a parts store and alot of people just replace stuff instead of checking in to whats wrong. I had plenty of people buy a computer, then try to return it for a refund, and want there old one back. Sorry, no can do.
Old Feb 25, 2011 | 10:12 PM
GLHS's Avatar
Yeah, I'm sure they don't return electrical items even though the old one tested by them was "bad" yet was good.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
ARbowhunter7
Feb 2, 2012 05:36 AM
jmlcolorado
Jun 6, 2011 08:21 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
jesussaves
Sep 18, 2009 07:53 PM
