95 4500 how do I get the shifter out?
Old Jun 27, 2009 | 01:35 PM
haddixj's Avatar
I am trying to take out a 95 Nv4500 how do I get the shifter out? I dont see any bolts, the roll pins in the side are just stops for the shifter side to side movement any ideas? thanks
Jason
Old Jun 27, 2009 | 02:53 PM
patdaly's Avatar
Either you have to us a puller to remove the stick from the stud, or I believe you can rotate the sleeve at the base to release the ball and all.
Old Jun 27, 2009 | 05:48 PM
JFlory's Avatar
Some are a real pain. You have to do like stated above. Rotate the sleeve at the base. You have to push it down while rotating. It sucks, and is even worse when you have to put it back on.
Old Jun 29, 2009 | 07:30 AM
patdaly's Avatar
Miller makes a tool, might find one on ebay reasonable........
Old Jun 29, 2009 | 09:46 AM
haddixj's Avatar
I was able to get it out. I had a set of curved needle nose that I was able to pry down on the lock ring and twist, it worked great thanks for the help.
W250TATE
May 24, 2011 01:07 PM
Baja
Aug 20, 2007 01:08 PM
swampthang
Apr 1, 2007 12:54 PM
v8440
Apr 10, 2006 04:05 PM
coolslice
Feb 13, 2005 05:14 PM
