My trailer power converter keeps running lights on!!!
I just finished wiring in a trailer power converter and attempted to wire it into the factory seven pin the power converter has a four pin pig tail that I spliced into the factory harness so it would transfer the basic functions for lights to the seven pin and replaced the four pin on the truck with the new one as the one that was there was pretty corroded. Now my parking lights stay on even when the switches and ignition are all off I had to disconnect it from the battery in order for them to shut off. The Power converter has input for brake, tail light, right and left turn, ground and of course the power cable from the battery. I have the Ground on the crossmember of the frame in the rear.I was wondering if the turn signals are 2 channel or 3 channel? this might help in diagnosing what is wrong, I double and triple checked everything to make sure I was wiring into the right wires from the tail lights and I am sure that I got those right because I tested all the turn signals and they worked fine I just need to find out what I did wrong that keeps the lights on. Any help would be hugely appreciated.
When you say "trailer power converter" it's just natural for the first though to be a power converter that is installed inside and RV that converts 120VAC into 12VDC. Also, with a full sized truck, a lighting converter like this:
http://www.ontheball.com/taillight_convert.htm
isnt necessary.
isnt necessary.
Bowser50
13
Jul 19, 2009 07:35 PM
Bowser50
Jun 29, 2009 08:02 PM
BRUISER
Nov 6, 2007 07:39 AM
sssmaly
Jul 13, 2007 12:57 PM
