47rh wont shift out of 1st
Old Oct 21, 2005 | 01:08 AM
Jambbii's Avatar
Well just had replace my output shaft and now my truck doesnt want to come out of 1st gear. I have read about the governor but not sure how it works. Any help would be appreciated!
Old Oct 21, 2005 | 01:46 PM
zukgod1's Avatar
Did you do it or have a shop install the shaft?
Sounds like something didnt get installed correctly though I'm FAR from an expert on autos.
just sounds like a stuck valve/solenoid not alowing the fluid to change directions.
Old Oct 21, 2005 | 08:43 PM
J BODY's Avatar
Ok, I know there are others that have read this that are thinking of the "trick" to shake the old school governor loose. anyone???anyone???
Old Oct 21, 2005 | 09:08 PM
got...DIESEL?'s Avatar
when you hung the OD back on the trans, did you take care to align the two pipes without tweaking them?
Do you have reverse as well?
It is 99% something didn't go back together right in the governor, i.e. the governor valve is stuck, the shaft or weights are damaged or assembled wrong or the sealing rings on the gov body or the OD housing bore where they ride were damaged upon reassembly.
Next thing to do is strap a pressure gauge on to her and check line pressures as well as governor pressures. Do you have the DC manual?
Let us know.........
Old Oct 21, 2005 | 11:02 PM
J BODY's Avatar
He did break a shaft so I was wondering about the "debris" factor. Might be a small piece stuck in the governor.
Old Oct 22, 2005 | 07:53 PM
Jambbii's Avatar
Well Got...diesel hit the nail on the head. I didnt line up the tubes. I figured it out when I pulle the tail housing back off and the tubes were bent. Everything is back together again. I will never do that again I guess you live and learn
VCB
Aug 14, 2013 10:23 AM
krammer'slawn
Jan 9, 2013 05:12 PM
Fergavs
Dec 8, 2009 09:54 PM
nottanuff03
Sep 23, 2009 03:47 PM
nottanuff03
Sep 22, 2009 10:25 PM
