24v Engine Problems...Help!
OK folks, here's the deal. I start my baby up and she sounds like she's running "soft"--not as throaty as she should be. If I rev the motor a little, it runs rough...instead of a steady rumble I get a bap-bap-bap sound and gray smoke. When I get going, I have VERY LITTLE power...enough to get up to about 30mph on a flat road. The truck will decelerate going uphill at 2000 rpm. I have already done the lift pump, as my fuel psi was getting on the low side. Once the truck gets to normal operating temp, she runs fine...no dead pedal or any other VP44 symptoms. This lead me to believe that the problem is heat related. I am at my wit's end guys and gals! I have had several near misses because I can't get up to speed. Please help!
From: Dayton, NJ (temporarily while In USCG on Staten Island)
Morning, well I would start with the easiest stuff first, read codes if any, fuel filter, short out injectors, fuel quality(is it gelling). How many miles on your truck?
Stephen
Stephen
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
