Head gasket problems on 24V???
Old Feb 7, 2003 | 06:53 AM
Gensets's Avatar
??? 2001; 2500; H.O.; 6 sp; 4X4; 53000 mi. Does anyone know whether or not the 24V engine is prone to head gasket leaks? Standing in front of the engine, the left rear corner of the mating surface between the head and block was squirting coolant. Took it to Cummins and the Service Mgr told me where it was leaking before I told him. He said "that's where they leak alright." Since this is my first diesel, I was just wondering if anyone else has had this problem. Thanks.
Old Feb 7, 2003 | 07:19 AM
Gensets's Avatar
Re:Head gasket problems on 24V???
Thanks for the info. I sure haven't heard of any problems and know several folks who have the same engine, but I thought I would throw it out and see what kind of response I got. Have a good day.
Old Feb 7, 2003 | 05:15 PM
willyslover's Avatar
most issues are on the HO's with high fueling anh high boost....a bunch have blown with high propane and NOS use also
Old Feb 7, 2003 | 06:05 PM
Scotty's Avatar
Top's Younger Twin
Kwik Kurts gasket went, mine went and a few others on here have failed. [not stock] No NOS or Poo Pane on mine. 8)<br>A stock ETH not warmed up in a cold climate and pulling a trailer is very prone to blowing a head gasket. A few oil patch folks with stock trucks that drove without a warm up have blown the gasket too.
Old Feb 7, 2003 | 06:45 PM
Don M's Avatar
DTR Advertiser
We should S-can the head gaskets altogether. If we mill the tops of the pistons down, precision lap the mating surfaces, o-ring the water and oil passages the head gasket troubles will be a thing of the past.
Now, where are we gonna find a surace grinder that will hold about 50 millionths tolerance for that large of part? :
Scotty, its high time we did our best to blow that o-ringed head gasket you have on your truck
Don~
Old Feb 8, 2003 | 01:14 AM
Bart Timothy's Avatar
Blown head gaskets are very common on ETHs. Even stockers are blowing them, but adding a timing box along with propane virtually assures a failure.
Old Feb 8, 2003 | 09:26 AM
Scotty's Avatar
Top's Younger Twin
[quote author=Don M link=board=4;threadid=10650;start=0#102024 date=1044665146]<br>We should S-can the head gaskets altogether. If we mill the tops of the pistons down, precision lap the mating surfaces, o-ring the water and oil passages the head gasket troubles will be a thing of the past. <br>Now, where are we gonna find a surace grinder that will hold about 50 millionths tolerance for that large of part? :<br><br>Scotty, its high time we did our best to blow that o-ringed head gasket you have on your truck <br><br>Don~<br>[/quote]<br><br>Answer my PM's and lets do it.
Old Feb 8, 2003 | 12:45 PM
John_P's Avatar
Gensets:<br><br>Sorry to hear about your headgasket! <br><br>I have to concur with what everyone has already <br>said; the ETH headgaskets are known to fail! And<br>they can do it in &quot;stock&quot; condition too! <br><br>Although I have an old &quot;antique&quot;12 valve, I blew<br>my headgasket about one year ago, so welcome<br>to the club! ;D<br><br>--------<br>John_P
ted_pulliam
Jul 16, 2009 11:33 AM
CUDANUT
Jan 27, 2008 10:40 AM
wildchild97
Sep 25, 2007 02:44 PM
dodgediesel
16
Sep 15, 2007 09:10 PM
MADSEN
Oct 7, 2004 09:43 PM
