map sensor code p0107
Old Dec 20, 2007 | 11:26 AM
driver03's Avatar
i changed out the map sensor on my 2003 dodge 3500 after a friend pulled the codes. the code that came up was p0107. the truck runs but it dossent have as much power like it should and the code wont go away when its cleared. any ideas?
Old Dec 20, 2007 | 11:47 AM
vzdude's Avatar
DTR's 'Go to Guy'
Wiring? IIRC there was a problem with the 5v reference wiring that fed the map sensor as well as the a/c pressure transducer and another 1 or 2 maybe. Look near the a/c compressor for bared wires. May not be it, but without a scanner to see readings and such, best guess I could come up with.
Old Dec 20, 2007 | 12:03 PM
cincydiesel's Avatar
I remeber getting this code when I accidently pulled the wire from the Edge J/A fuse tap into the transmission fuse. I reinstalled the fuse and all went away.
nesbob
Dec 10, 2009 07:01 PM
1985cucv
Apr 4, 2009 09:30 PM
Moobesor
Feb 23, 2008 09:57 AM
53 willys
33
Jun 7, 2007 11:01 PM
bighornrmk
Apr 28, 2007 01:38 PM
