2006 dodge 2500 dana rear end
Old May 27, 2007 | 04:17 PM
trucklvr's Avatar
does anyone know what size socket i need to remove nut on my pinon flange so i can replace seal any help appreciated
Old May 27, 2007 | 04:25 PM
TheBigNasty's Avatar
It's an AAM axle.
Old May 27, 2007 | 04:41 PM
TonyB's Avatar
I assume you're dong the work because the truck's out of warranty?
Old May 30, 2007 | 06:50 PM
trucklvr's Avatar
yes it is out of warranty and i dont take anything to dodge if i can help it
Old May 30, 2007 | 08:45 PM
jkitterman's Avatar
You are better off taking it to a mechanic of your choice that does diff work. It needs to be set properly or you can ruin the diff.
Old Jun 1, 2007 | 04:22 PM
trucklvr's Avatar
i am only replacing seal behind flange so i dont need to set anything on rear end have done this seal on my ford f250 with posi trac rear end no problems easy job to do seal
Old Jun 1, 2007 | 06:51 PM
J BODY's Avatar
didn't know ford used AAM axles?
Old Jun 1, 2007 | 10:46 PM
jkitterman's Avatar
The service manual says it needs to be set back up with an in/lbs wrench and to use a new pinion nut.
Old Jun 2, 2007 | 06:41 AM
dieselrob's Avatar
Im not shure if its the sam numbers, but on the dana it should be set to some where between 15- 27 in/lbs. and a new nut is to be used. I dont remeber the size off hand tho.
Firstgenfanatic
Sep 16, 2010 01:37 AM
RichN
0
Aug 6, 2010 06:52 PM
bdf
Jun 15, 2010 04:07 AM
doorguy
Jun 8, 2007 06:19 AM
matthopp
Nov 21, 2003 04:49 PM
