2001 Wont Run
Old Mar 7, 2009 | 10:51 PM
apperry123's Avatar
2001 Wont Run
i have a friend with an 01 ctd. It died going down the road and it wouldnt start. he took it to a local shop and they replaced the lift pump and injection pump. they also replaced the crank sencor and injectors. NO LUCK. NEED HELP
Old Mar 7, 2009 | 11:34 PM
TLDC's Avatar
Might need to relocate the fuel pump (lift pump), if it's in the tank or just outside of the tank. Mid-line would probably work best. The shop did check the fuel filter right?
Old Mar 7, 2009 | 11:41 PM
apperry123's Avatar
Hes got a fass pump on the rail. and they did change the filter. he also has a bigger turbo with edge comp.
Old Mar 7, 2009 | 11:51 PM
TLDC's Avatar
I hate to tell you this but they had to replace my injector pump (VP44) twice the 1st rebuilt one was defective...maybe it's the same thing.
Old Mar 8, 2009 | 08:29 AM
tctblades's Avatar
I had the same problem with mine and it ended up being a broken wire underneath the fuse box under the hood. so try unbolting it and take it out some and on mine it was a red wire. Hope this helps
Old Mar 9, 2009 | 12:40 PM
apperry123's Avatar
they got it running now but it misses. im starting to think this shop is not qualifyed to work on diesels.
Old Mar 18, 2009 | 08:40 PM
apperry123's Avatar
it was a bad connection on the fass
rattlebox01
Nov 6, 2009 12:28 PM
Stroked-Z
Oct 4, 2008 11:28 AM
Mariner 250
Oct 10, 2006 03:31 PM
FANZDSLPWR
Aug 2, 2006 12:07 PM
Holycack
Jun 27, 2003 03:26 AM
