2000 CTD Need to Drain Fuel Tank
Old Mar 22, 2008 | 11:55 PM
IBenDCars's Avatar
I am getting rid of my truck and need to drain the full tank of fuel I just put in it. What is the easiest way to empty it out? Will a siphon hose work or do I need to pull lines off or anything like that? Thanks
Old Mar 23, 2008 | 07:54 AM
AlpineRAM's Avatar
Use the water drain on the filter- slip a hose onto the short hose, with the engine idling you can let a good amount of fuel run from there without problems (as long as your lift pump is up to par)
HTH
AlpineRAM
Old Mar 23, 2008 | 09:08 AM
IBenDCars's Avatar
HTH
AlpineRAM
a little worried about the lift pump, partly why she is going bye bye
Old Mar 23, 2008 | 09:48 AM
infidel's Avatar
Some trucks have a rollover ball in the fill line that prevent getting a siphon hose down. Easy to remove the fill and vent lines from underneath, pull it out from under the fill lid then siphon.
Old Mar 23, 2008 | 12:29 PM
IBenDCars's Avatar
will try that thanks
Old Mar 23, 2008 | 12:55 PM
johnh's Avatar
i may be wrong, but there is no rollover ball on the diesel of that year. at least there isn't one on mine
Old Mar 24, 2008 | 10:12 AM
infidel's Avatar
I still haven't figured out why some have the ball and others don't. Could be the difference between years, 3500 or 2500 or maybe even different state laws.
jeeper50
Sep 29, 2011 06:04 PM
klx650a2
Jan 10, 2008 12:08 AM
kully560
0
Jan 21, 2006 02:22 PM
shellman
Nov 30, 2005 07:38 PM
wooff
May 1, 2003 11:22 AM
