slams reverse/snap on accell
Old Mar 5, 2008 | 06:31 PM
benroberts3605's Avatar
01 24valve 4x4 auto
i get a hard slam from the rear end when i put it in reverse and a snap soundfrom it when i accel from a dead stop. ive put the truck up on a rack and i have aruond 1/2 inch of play wich isnt bad but when i look at it on the ground going from drive to reverse its really excessive. any ideas?
Old Mar 5, 2008 | 08:09 PM
Dean Snow's Avatar
Did you check your U-Joints? Thats sorta what it sounds like.
Old Mar 5, 2008 | 10:40 PM
WildBill's Avatar
A 1/2" of play in what? How many miles on the truck?
Old Mar 5, 2008 | 10:48 PM
merrillr4's Avatar
I agree! I had the same problem a few weeks ago and it ended up being the rear u-joints.
Old Mar 6, 2008 | 07:02 PM
the truck has 124000 miles its about a 1/2 inch play in the rear diff. thanks to all that replied.
Old Mar 7, 2008 | 11:05 PM
Common's Avatar
Wiggle your driveshaft back and forth - might be a pinion bearing.
Old Mar 20, 2008 | 06:54 PM
rhino 660's Avatar
mine is doing the exact same thing and it's getting worse im thinking its the trans do 1st gear and reverse sare the same clutch packs?
Old Mar 23, 2008 | 11:19 PM
Dangousity's Avatar
My Ujoints got so bad that the tranny started vibrating. Beat (tapped) the drive shaft with a deadblow and found the ujoint, but with my hands I couldn't tell.
Old Mar 24, 2008 | 09:10 AM
Diesel_Dan's Avatar
If you mean the whole pinion shaft is moving a 1/2 inch then you have problems with your pinion bearings. Either way a 1/2 inch of movement in the driveshaft is bad news.
Old Mar 24, 2008 | 10:56 AM
Smokee's Avatar
I think you should consider the low reverse band in the tranny if the U-joints are OK
got_soot
Nov 17, 2010 08:51 AM
NDanecker
Jul 21, 2008 10:19 PM
sherpadad
Aug 1, 2007 10:08 AM
2500QC
Dec 28, 2005 05:35 AM
