03 running horrible
03 running horrible
Today i noticed when i really get on the pedal my trucks starts running real bad once it gets to about 2300 rpms. So i took it easy and then when i came to a stop sign it just died on me. Well i got it started again and it will run ok for a minute and then start cutting out again and die. So i went and got a fuel filter and changed it and got it started and it ran real strong for about two miles and then it started missing real bad at 2300 rpms again. Does anyone have an idea what is going on? Its all stock
From: In Oroville, Ca., same house for past 46 yrs!
lift pump going or gone...
do a search here for all kinds of alternatives. I put 3 on my truck before it finally got to 100,000 miles and then I went to twin holleys and an adapter plate on my filter housing.
Is the lift pump hard to replace or something i need to have done? Im not a professional mechanic or anything but i do like to try and save every dollar possible since im only 22 years old and dont get my money from my parents.
yes it comes with everything too. i just noticed you have an 05 is your lift pump in the tank if so you will want to get the 150 so you get the new pickup tube you will have to drop the tank to put it in good luck and i dought that anyone is going to have it in stock it just came out the middle of december call pureflow they will tell you what you need they are nice people.
Looks like he has an '03 as well. I'm pretty sure that's the one he is talking about. Agreed, sure sounds like a lift pump. Tons of options. Just do some research first. I chose the Walbro pump for eas of installation, ease of replacement, and you can typically find some sort of pump at most auto parts stores to put in it's place to get you where you're going in a pinch! Can't do that with those pumps that have the filters and all included in them, withough bypassing the filters.
yea where is the lift pump located at on my 03? I read its mounted on the back of the fuel filter canister but when i changed the fuel filter i do not remember it being mounted on the back of it.
it is a little black canister looking thing on the back side of the filter unless it has had the dodge update and it has been put in the tank if has then it has the same style pump as the 05
cowboyup007
Apr 10, 2011 09:04 AM
