What is the best year for the CUMMINS?
What is the best year for the Cummins? for reliability, and for plain ole' hot rodding.
I have heard the 98.5 is the best and i have also heard any 12V is the best, what is you all's opinion. AND WHY?
That there is a loaded question. You might as well forget it. You're going to walk away more confused than before you asked.
Most reliable - I'd take a 12 valve due to the P7100, and simple mechanical nature of the beast. 98 model for the quad cab, and 12 valve. 98.5 went to the 24 valve.
Most power - I'm sure you can pump out plenty o' power with a 12 valve, but it just makes sense that the more valves you have, the more air you can blow through the pump. So, take your pick of 24 valves, I guess.
The main problem with this question is that you can get more power than you need with basically any Cummins powered Ram, and plenty of reliability once you have just 1 or 2 small items tackled. If I were to narrow it down, I'd say the '92 models through the '07 (excluding the '07.5) were the best for reliability and hotrodding.
- JyRO
- JyRO
reliability can be sacrificed with too much hotrodding. as with anything.
the newer common rails are easier to build quick, cheap power with. just plug in a downloader or module, and easily 130 hp additional.
As far as reliable, depends on the trans you get and how much you abuse it.
then why is it that when someone P Pumps a 24v they just dont put the 12 valve head on as well? i dont thinks its possible for a 12v ported head to outflow a ported out 24v head? as far as a 24v turning 4k rpms, just go buy a redline box and there ya go, 4k rpm beast
24v's scare me w/ the shared rocker... seen what happens when a valvespring breaks!
97...
Best year Dodge Cummins PERIOD.
Latest "Old Style" 2nd Gen, so EVERY bug was worked out (minus the KDP) and no chance of a 53 block.
Most hot rodders including the 7 second Cummins dragster use the P7100 which is by far the best injection pump money can buy...
kinda biased but seems 97 just before the 53 block issue would be the best. 98.5 12V QC LB without a 53 block could be better.
and yes I've been trying to find a low mileage 98.5 5sp...
97...
But to be honest about it. ANY P7100 12 valve will be about as reliable as you could ever hope for.
Eric
