Sponsored by:
Sponsored by: CARiD
Tools?
Old Aug 6, 2007 | 04:39 PM
ozob nospej's Avatar
Tools?
Any makers making special tools for the high pressure lines? Like a flare nut wrench? I'm wondering what the pros are using. The Puller needed for the
VP44? You get the idea.
Old Aug 6, 2007 | 04:48 PM
vzdude's Avatar
DTR's 'Go to Guy'
I use regular wrenches for the fuel line nuts, a flare wrench if they are REAL tight, and for the gear puller, I use a steering wheel puller. Just a cheap 2 bolt puller. Had to get different bolts though because the ones that came with it were the wrong thread. Can't remember what the thread was right off hand, but I think it was metric!?
Old Aug 6, 2007 | 05:24 PM
Yes the threads are 8mm!
Old Aug 6, 2007 | 08:29 PM
dieselrob's Avatar
The bolts that either hold the airhorn or the black throttle linkage assembaly will work also.
Old Aug 7, 2007 | 07:20 AM
bentwings's Avatar
I got a crow foot flarenut set at Harbor Freight that solved the #5,#6 inj. line problem. I got the stubby 19 too but the crow foot reall does the job best.
Just use the intake bolts for the puller. Mine didn't feel right but I think there was carbon or something inthe threads. Once I ran a cheap 8mm thru they worked fine. The gear is case hardened sothe hole may have shrunk a bit too.
cheapo steering wheel puller.
metric and US sockets and wrenches.
I have 2 big metric sockets 21 and 24mm ??? can't remember. For the alternator nut and the VP nut.
Short 10 mm comb wrench must be 12 pt for the starter.
2# ball peen
never seize
teflon tape...yeah I know about threads.
small and med vice grips
a few mixed screw drivers.
Torx set.
3/8 allen socket. Good one from Sears for brakes.
brake spoon for rear drums
serpentine tool set and belt. Got to use it on the road. Save a very, very long and cold walk.
spare lift pump...haha
a few other things.
Old Aug 9, 2007 | 10:44 AM
<snip>
I got that crowfoot and that was a lifesaver! I had most everything else. I'm doing a VP44 (250K miles) and the 3/4 crowfoot is a must-have to get at #6 and even #5. The lowest rear connection to the pump is much easier with the crowfoot as well. Thanks
Old Aug 9, 2007 | 12:04 PM
vzdude's Avatar
DTR's 'Go to Guy'
I always just take the front 3 lines off, and finagle around the other 3. But whatever you're most comfortable with! LOL
Old Aug 9, 2007 | 01:32 PM
Dinner's Avatar
When I was removing my injector lines, I just used regular box-end wrenches(metric since that is what I had at the time). I found it fairly easy to get to #5 and 6 actually. Removed the engine lift bracket at the rear of the intake and then went at it.
Mcmopar
Mar 8, 2004 09:08 PM
corey
Feb 14, 2003 02:28 PM
fboese
0
Dec 10, 2002 04:01 PM
Nov 4, 2002 12:03 PM
