Sponsored by:
Sponsored by: CARiD
HOLY MAN 2009 2500/3500 Cummins is 425HP!!!
Old Nov 1, 2008 | 02:28 PM
74dart's Avatar
As somone said before they are the hp and tq figures for the 6.1 srt motor some web designer got his facts wrong.
Old Nov 1, 2008 | 05:26 PM
AH64ID's Avatar
Originally Posted by Steve-l
Excuse me folks, the add is simply in error. HP = torque x rpm over 5250.
So, if you exptrapolate you will have 425 = 420 x 5188 / 5250 I never saw a Cummins run at 5188 RPM. Even 425 HP at 650 ft lbs does not compute, because the Cummins won't go 3800 RPM either.
True.. but we need to know what RPMs they are talking about to use the math... Without knowing what rpm the engine is rated at we can't use the math. And that function only tells you data for that specific rpm. And diesels don't make max hp and max tq at the same rpm.
But yes it is an obvious error.
The real data is 350hp at 3013 rpm, so at 3013 its making 610fts.. at 650 ft lbs at 1500 rpm means its making 186 hp.
Old Nov 1, 2008 | 10:35 PM
Butchy Boy's Avatar
I thought I heard rumores that Cummins was designing a v8 diesel for dodge, and the inlines were heading to chevy for 2010 anyhow
Old Nov 2, 2008 | 09:14 AM
AH64ID's Avatar
Cummins says there are no plans to move the ISB to any other mid size platform.. Thou I did read about a V8 design for 1/2 tons.
Old Nov 2, 2008 | 07:35 PM
bob4x4's Avatar
The torque is limited by the computer software on all the Cummins common rails so any strange #s would be possible
I have seen Cummins 5.9s run over 5k at the pulls
Bob
Old Nov 5, 2008 | 04:02 PM
supr's Avatar
If you look in the lower section, it staes "650ft/lbs torque.." They somehow picked up the Hemi specs.
So, 12V's do not make this, normally!
Old Nov 6, 2008 | 01:18 AM
wcbcruzer's Avatar
Originally Posted by Butchy Boy
...the inlines were heading to chevy for 2010 anyhow
Are you serious? Last thing we need is the Cummins to move over to Chevy. Coupled with the Allison, Chevy owners will run their mouth all day.
JDP
Big Rigs
Nov 15, 2009 08:31 PM
jlau6888
Nov 27, 2008 12:25 AM
lexustech48
Oct 29, 2007 05:44 PM
reidry
15
Dec 20, 2005 09:35 PM
Diesel-Dan
Mar 2, 2005 04:27 PM
