Sponsored by:
Sponsored by: CARiD
Fords on Fire
Old Mar 25, 2007 | 03:07 AM
  #136
Steven K's Avatar
So the fix is just a computer reflash to power down the engine in the case of a leaky injector dumping more fuel into the exhaust.
That's what I thought, it's just a safety bandaid deal.
Old Mar 25, 2007 | 03:40 AM
  #137
XLR8R's Avatar
Wow - that flame video is just amazing to watch... unbelievable.
I take it that the extra injector responsible for heating the DPF when it's in regen mode is leaking?
Very dangerous, IMO!
I hope Dodge procures the new urea-based emissions system from MB for the next model year, or ASAP - from an engineering standpoint, it seems as though it's a simpler, more efficient and inherently safer design than the current DPF interim solution.
Old Mar 25, 2007 | 07:34 AM
  #138
MegaRam's Avatar
WOW...........
That video is unreal........
And man that motor sounds like hell.....
Old Mar 25, 2007 | 07:36 AM
  #139
79warlock's Avatar
I doubt they have an extra injector. With computer controlled injectors you can easily use a post injection event to put unburned fuel to the exhaust.
Old Mar 25, 2007 | 11:12 AM
  #140
No, it's one of the cylinder injectors. If it wasn't in regen mode then you'd just see some white smoke instead of 2 foot flames.
Old Mar 25, 2007 | 11:36 AM
  #141
1stGen545's Avatar
Man Dave's always got the answer. Thats why I like that guy even tough I have got in trouble a few times. I didn't think it would have an extra injector, but didn't know if it used 1 or 8 to raise the temps. the 07 dodge 5.9 dose the same thing to clean out the DPF. Fords plob is all because of a leak not in the design itself.
Old Mar 25, 2007 | 11:45 AM
  #142
XLR8R's Avatar
Does another OEM's DPF design use an extra injector?
I thought I read about it last year in an emissions compliance article...
Old Mar 25, 2007 | 12:49 PM
  #143
graphitecumnz's Avatar
The 07 Dodge with the 5.9 doesn't have a DPF... that's the 07.5 Dodge with the 6.7.
Old Mar 25, 2007 | 01:07 PM
  #144
Smkndzl's Avatar
The Cummins Heavy Duty ISM and ISX uses a aftertreatment injector for hydrocarbon injections. the ISB uses a very late post injection during the exhaust stroke for oxidation heat in the aftertreatment. The use of Urea is coming , but you will still have the DPF, Urea is only for reduction of the NOx output from the engine. you still have to trap the PM from the engine. Urea will not reduce the PM.
Old Mar 25, 2007 | 01:08 PM
  #145
79warlock's Avatar
You may be right but that would seem like a step backwards in technology. Everybody making big deal about the new piezo electric injectors and all,and for them to not use the system to it's full capabilty seems so...like something FORD would do. So you probably are right!
Old Mar 25, 2007 | 07:38 PM
  #146
1stGen545's Avatar
the 5.9 manual said it dose and I see it under the truck
Old Mar 25, 2007 | 08:26 PM
  #147
79warlock's Avatar
Are you sure it's not a cat you are seeing?
Old Mar 25, 2007 | 11:19 PM
  #148
There is no need for a DPF on the 5.9 engine. It does not fall under the auspices of 2007 Emissions Regulations.
Old Mar 26, 2007 | 01:00 PM
  #149
SoTexRattler's Avatar
MB's Bluetec diesel on the new E series have an extra injector for the DPF. (from what I've read about it)
Actually driven my B-I-L's new E series bluetec powered sedan.. WOW! LOTSA power!
We could see an extra fuel line headed back towards the turbo exhaust area. (couldn't see much beyond that).
K.
Old Mar 26, 2007 | 02:27 PM
  #150
Springer's Avatar
Mine only has a cat and the muffler ...
not for long though
Puke
May 8, 2007 10:04 PM
pianotom
Jun 15, 2005 03:34 PM
cp
Jul 5, 2004 07:05 AM
sgrooms
Mar 18, 2004 08:31 AM
NWDave
Dec 1, 2002 07:09 PM
