Sponsored by:
Sponsored by: CARiD
Ford 6.0l Idle Problem
Old Aug 13, 2009 | 06:42 AM
74dart's Avatar
What would cause a loping idle on a 03 Ford 6.0l superduty?
Old Aug 13, 2009 | 07:34 AM
cincydiesel's Avatar
With a 6.0 who knows.. Could be a number of things.. My guess would be fuel pump related
Old Aug 13, 2009 | 12:46 PM
cadash's Avatar
Hey 74 dart. I think it could be your HPOP or FICM. If you have access to the Auto Enginuity it could help you out a little more in resolving it. I have it and Im outside of Jacksonville by Burgaw.
Old Aug 13, 2009 | 03:59 PM
mini14's Avatar
have ecm flashed first, or could be sticking spool valves in the injectors...stupid heui design.
Old Aug 13, 2009 | 04:07 PM
cadash's Avatar
The new FICM reflash is out as well.
Old Aug 13, 2009 | 05:10 PM
74dart's Avatar
It is not for my truck but somone that I work with.
Old Aug 13, 2009 | 07:27 PM
rbrettctd's Avatar
It's a 6.oh no, best bet is it's ready to commit suicide, jk. Start with an oil change, I know the old 7.3's would get a goofy idle sometimes with old oil, also would look at the HPOP, FICM, or maybe an injector problem. Good luck. If all else fails, maybe it needs a Destroking.
Old Aug 14, 2009 | 09:15 AM
Hvytrkmech's Avatar
IPR valve, injector pressure regulator.
Old Aug 14, 2009 | 05:59 PM
rebal's Avatar
Ditto on the oil change (stupid HPOP) then check for air or fuel leak or blown Oring in the HPOP.
Old Aug 14, 2009 | 08:08 PM
MTC's Avatar
MTC
I went through 4 EGR valves on my old '04 sick.0....I know that the idle would lope when one went bad. But prob the HPOP or injector like stated above.
Old Aug 14, 2009 | 08:48 PM
lanwangeek's Avatar
I could be a injector. Is it a early build 03 (built Jan to Mar) They had injector problems in those models and recalled the injectors back from the dealers, but if they where installed in the truck, you where out of luck. I had a early 03 that Ford ended up buying back. Every time I had a injector fail, I would argue to replace the rest, but they would refuse. Anthony
Old Aug 14, 2009 | 11:42 PM
67HotRod's Avatar
I'd ask your buddy first if he had all the recalls & TSB's done.
Old Aug 15, 2009 | 06:55 AM
ktpauley's Avatar
Like lanwangeek stated the early 6.0 had real bad injectors(C94) i think. They were replaced with C95 injectors. If the oil level in the crankcase rises then there are bad O rings in the injectors.
A SCT with custom tunes can tur the EGR off in the computer.
Keith
Old Sep 4, 2009 | 04:12 PM
mdbreaux's Avatar
Rough Idle Bad Injectors
I have been through this all too many times. Bring it for a diagnostic to be done when the engine is completely cold. Leave it there overnight and have them start it up in the morning. I am sure you will find several bad injectors. If it is not under warranty, I would advise changing them yourself, unless that is over your mechanical abilities. The injectors themselves cost 220 dealer cost with core exahcnge and I can't imagine what the labor is. If you are lucky, they will be on the driver side because it is easier to get to. If you are really lucky, only a glow plug or two will be out and not the injectors. I would have it checked soon. Michael.
Pele
Cummins Conversions
May 21, 2014 06:49 AM
freds89
May 7, 2009 08:54 PM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
