Sponsored by:
Sponsored by: CARiD
duramax injectors - sorry
Old Oct 29, 2007 | 09:27 PM
whiskeyrichard's Avatar
My nieghbor needs to replace the failing injectors in his d-max. It is an 03.
I have had bad luck finding nearly as much info on the web about d-max injectors as I have finding info for cummins injectors.
If any of you could send me a message with good info or where to look I'd appreciate it.
His truck is stock other than a hypertech programmer and a after market intake. He tows and would like to stay with a mild performance increase and hopefully mileage increase as well. He has a full set of guages.
Thanks for the info.
Old Oct 29, 2007 | 10:02 PM
graphitecumnz's Avatar
does his truck fall under the umbrella of extended GM warranty... 7 year/200,000 mile warranty info
performance injectors are out there but full injectors are pricey... $2k a set... nozzles are about half that...
Old Oct 29, 2007 | 10:18 PM
duratothemax's Avatar
performance injectors are a waste of money on all but the most powerful duramax's.
stock duramax injectors flow enough fuel for 700+ rwhp and 10 second quarter miles...
Old Oct 30, 2007 | 08:22 AM
Boss Hoss 540's Avatar
I have 3 friends and all had the injectors fail before 75k!!! That is a big weak point in the Duramax..
Old Oct 30, 2007 | 10:46 AM
only the first gen dmax's (01-04) eat injectors...huge problem, it was so rediculous that GM extended the injector warranty to 200k.
I just saw one with 580,000 miles, its been through 5 sets of injectors. everything else is fine though! haha
ben
Old Oct 30, 2007 | 12:00 PM
Grit Dog's Avatar
Try www.dieselplace.com. It's the DTR for GM diesels. Lots of good info.
Assuming the '03 is under 200k mi, the warranty has been extended to '03 models as well as '01-'02.
There are specific symptoms though that are warrantied, some types of failures aern't, so read up on the TSB (whatever it's called), it's posted all over dieselplace in various LB7 threads.
From what I've read, some dealers are very liberal w/ their warranty on injectors and some are looking for any reason to deny the extended warranty, so it may be best to travel (if necessary) to a "good dealer" to save some hassles.
Knock on wood, 75k mi on mine and NO injector problems. Have about 22 mo of warranty left.
Old Nov 13, 2007 | 11:31 AM
Boilermaker08's Avatar
ben
5 sets of injectors @ $4,000/set installed = $20,000
You could build a nice heavily modded 12 V for that price!
Old Nov 13, 2007 | 03:57 PM
3 of the sets were covered under warranty
4,000 installed is a rip off.
Old Nov 13, 2007 | 04:34 PM
cbtumedic's Avatar
I don't know about that being a rip off, those injectors aren't cheap, internal warranty cost on them is like $250-300, and warranty labor is over 8 hrs. a set. There's a lot of work involved in that particular job and those injectors are a fairly advanced design with very exacting tolerances. We aren't talking about 12v injectors here, these things have to be able to contain up to 30k psi and are electronically controlled. I wouldn't want to foot the bill, but it's a lot better than when they were new and the injectors were $700+ each, warranty cost. Luckily i see you have an LLY so you don't have much worry about that. What kinda dyno numbers you puttin down?
Old Nov 13, 2007 | 05:05 PM
MTGunNut's Avatar
ben
It least GM will step up and deal with the problem.
Old Nov 13, 2007 | 10:00 PM
Injectors are about 1400 or so per set...IMO 2500-3000 is a better estimate...still a rediculous price and terrible problem that should have been corrected a long time ago. Labor is also insane because its impossible to get to them; I have only done a set of LB7 injectors with the engine out of the truck..I cant imagine doing them in the truck. Not like a CTD where everything is actually easy to get to.
I have no idea what my truck dyno's, and to be honest I really dont care. Dyno numbers arent really an impressive display of power in my own humble oppinion...they can vary from dyno to dyno, day to day, truck to truck, type of dyno, shift spikes, etc........ Id much rather see something run at the track or sled pull. Mine runs high 12's on fuel only, 106-107mph trap speeds, and weighs 7600lbs with me in it. Thats not very impressive at all in the diesel world, but it does everything the way I want it to, tows the way I want to, and works the way I want it to... BUT my engine is stock with 76,000 miles on it, stock head bolts, stock head gaskets, stock injectors, stock everything, except I bolted on an aftermarket turbo that runs 40-45psi. Every part on the engine is factory original except the ECM which fried at 12,000 miles. Trans is all stock hard parts, I built it myself with suncoast clutches and a suncoast torque converter. I tuned the truck myself with efilive, theres probably the main problem right there!
ben
Totallyrad
Jan 7, 2008 05:31 PM
KRB
May 20, 2007 06:20 PM
cumminsboy
Jan 20, 2005 09:38 AM
BIGOKIE
Jul 21, 2004 05:53 PM
fschiola
Jun 16, 2004 08:53 PM
