Sponsored by:
Sponsored by: CARiD
Can we re-use Synthetic oil?
Old Oct 24, 2004 | 09:28 PM
Scotty's Avatar
Top's Younger Twin
Question Can we re-use Synthetic oil?
I heard that you can save your synthetic oil, let it settle out over a few weeks and you can use it again. I got this from a diesel mechanic last week. I thought that the oil would break down or contain contaminants?
Several folks have said that changing synthetic sooner then 30K miles is a waste of money too. Is that true?
I have also heard that when not using a remote bypass filter, you can do fine with changing out your oil filter every 15K miles.
So you dump the oil after 30K, let it settle out and then its ready to go again?
This thread is not here to incite a brand war...just looking for some answers with some factual proof. I would love to change my oil less if it makes sense.
Scotty
Old Oct 25, 2004 | 04:49 AM
infidel's Avatar
The additives in any oil get depleted with use, letting it settle out isn't going to bring them back. Also the oil can only hold so much soot before it will hold no more, that's were a bypass filter comes in.
Important part of extended oil changes is replenishing the additive package when adding make up oil with a filter change, don't it think would be wise to stretch it too far. 15k isn't too far though, I go 10k on oil/filter changes with dino Delo.
Regular oil analysis is very important with if you want to go further. I've read of guys going over 75k without changing synthetic oil but they still add a quart or so at 5-10k filter changes and run a bypass.
Old Oct 25, 2004 | 08:09 AM
Lightman's Avatar
Scotty I'd be really hesitant to believe any settling stories or reusing oil.
Based on my experience with the 305/555, which is pretty easy on oil, most likley you can do 10-15k on a quality synthetic without problems, but a $15 oil analysis test sure would help you know exactly what the best interval is.. My advice is to get some delvac 1 and sample it after 10k miles. Then you'll have a good idea how far you can go.
Old Oct 25, 2004 | 08:23 AM
RustyJC's Avatar
Over its lifespan lube oil will suffer, among other deterioration, additive depletion, contamination with weak and strong combustion acids, water, fuel, etc., buildup of soot as well as changes in the molecular structure of the oil itself through oxidation, nitration, molecular shearing of long chain hydrocarbons, etc. If the detergency package is doing its job, it's going to hold contaminants (including soot) in suspension, so settling isn't going to allow these contaminants to drop out. Of course, settling also isn't going to replenish depleted additives or restore the molecular properties of the base stock.
When it comes to lube oil, I'd listen to a tribologist over a diesel mechanic.
Rusty
Old Oct 25, 2004 | 09:26 AM
Scotty's Avatar
Top's Younger Twin
What my gut feeling was and what I just read here is what makes sense. I will continue to run with 15K changes on 5W40 synthetic.
Will take a sample this change too.
Thanks for the confirmation of what I figured would be the issues.
Scotty
Old Oct 25, 2004 | 12:13 PM
Lightman's Avatar
Scotty I wouldn't run 15k on just any synthetic, I'd be sure it's an extended drain synthetic that's got a high TBN and beefy additive package. I wouldn't run rotella synthetic or valvoline for that long but amsoil or delvac 1 or redline I would ..
Old Oct 25, 2004 | 06:09 PM
Scotty's Avatar
Top's Younger Twin
Maybe I would be better off to run dino and change it more often then because the price of the redline etc is insane here.
I never bought a bottle of wine for more then 3 bucks, why would I buy a quart or liter of oil worth triple my comfort drink?
Just kidding.
Old Oct 25, 2004 | 08:23 PM
Pavement_hater's Avatar
Delvac 1 can go 4x the normal oil change when an extended life filter is used per Mobil.
Old Oct 25, 2004 | 08:27 PM
Geico266's Avatar
Rusty, you hit the nail on the head. And would you believe there are guys that add used engine oil to their fuel? Not this CDT owner. NEVER! Reusing used engine oil is like eating your own waste! Just flush it for goodness sake! There is a reason they call it WASTE OIL!
(all used oil should be disposed of properly! )
Totallyrad
Jul 19, 2011 07:41 AM
JG FENCING
Dec 12, 2007 07:35 PM
EverydayDiesel
13
Jul 24, 2007 06:08 PM
Dodge Trucker
17
Nov 12, 2005 12:32 AM
dcwm
28
May 14, 2003 02:42 PM
