Sponsored by:
Sponsored by: CARiD
8.3 in a Freightliner Performance ?'s
Old Jan 15, 2006 | 08:31 PM
robsredford's Avatar
I have had a few freightliners with 5.9's, but I just got one with a 8.3, it runs real well, what can I do to it to get more power out of it reliably? it is rated at
225 hp now and i think they were rated up to 300 or 330 in some applications...whats different is it turbo and injectors only or are pistons and internals different...its a 98 mechanical btw...thanks in advance rob
Old Jan 15, 2006 | 09:22 PM
gman07's Avatar
A lot of the 8.3's also have the P7100 injection pump, so you can start there with a plate/delivery valves/GSK... http://scheiddiesel.com/index.htm Scheid will be able to get you all the performance you want, I'm sure. Any time you up power, you decrease the reliability/durability, but small mods shouldnt hurt as long as you have at least a pyrometer.
Old Jan 18, 2006 | 08:24 PM
Called Them...said All They Could Do Was Turn Pump Up Bout 10 To 15 % Ask About Plate And Other Mods And Told No...any Body Else Got Some Ideas?
Old Jan 18, 2006 | 08:35 PM
gman07's Avatar
I'm sure they would know better than I. What are the first 5 letters/numbers on the identification tag on the side of the pump?
Old Jan 27, 2006 | 10:28 AM
nevrenufhp's Avatar
that sounds strange that they say that. I have a DT466 and have a #0 plate from my old Dodge, plus I know a 3k GSK will fit & work in it.
Old Jan 27, 2006 | 05:28 PM
Monty's Avatar
They probably said that because this is in a medium duty truck that will see more constant heavier loads and sustain higher engine loads than a 1 ton truck.
Old Jan 28, 2006 | 11:08 PM
C Schomer's Avatar
Call Mark at TST Products. I'm sure he knows what to do to the 8.3 - he had a 550 hp 8.3 in 97 when I first bought goodies from him. Craig
Old Jan 29, 2006 | 09:38 AM
nevrenufhp's Avatar
On other sites, like TST & Piers, it's the same plate for both engines. Find the marine injectors for the 450hp 8.3, with a plate, 3k GSK, and maybe a second turbo, you'd be pushing some good hp #'s...past 450.
jesussaves
Big Rigs
Mar 15, 2024 09:44 AM
gman07
Jul 2, 2005 10:10 AM
Jim Shulmister
Feb 20, 2005 07:04 PM
gwhammy
Jan 26, 2004 06:57 PM
Haulin_in_Dixie
Nov 2, 2003 04:38 PM
